Platinum headlight bulbs
Old Nov 5, 2017 | 04:56 AM
Aceman21's Avatar
what headlight bulbs are in the 2017 maxima platinum ? I know they’re are led but what brand and size please. Thanks
Old Nov 5, 2017 | 10:54 AM
NisCal17's Avatar
Low beams are H11, High beams H9, Fogs H16.
Old Nov 5, 2017 | 11:01 AM
Aceman21's Avatar
what brand of led bulbs
Old Nov 5, 2017 | 11:03 AM
NisCal17's Avatar
Probably Nissan’s brand.
Old Nov 5, 2017 | 11:20 AM
Aceman21's Avatar
so what would be the closest I can buy to stock ?
Old Nov 5, 2017 | 04:42 PM
NisCal17's Avatar
Not really sure. Go to the dealer they can replace it under warranty if not get some H11 leds on Amazon.
They range from 30 to 100 bucks per pair. You going to need 6000Ks.
Old Nov 5, 2017 | 05:10 PM
A36-SR's Avatar
Stock leds cant not be replace there full seal it has to be the full headlight assembly.
Old Nov 5, 2017 | 05:33 PM
Aceman21's Avatar
I only wanted to know because I wanted them for another car. I like how bright they are and how well they light up raid signs and such
Old Nov 6, 2017 | 09:16 AM
craziexstylez's Avatar
Every car is different. Not all of them uses the same bulb size. Look up your vehicle bulbs size thru google or your owner manual. But if you want the led look headlight, make sure you get them in 6k temp. It’ll be the closes to OEM led.
Old Nov 6, 2017 | 09:34 AM
Aceman21's Avatar
I know they are all different. Like I said, just wanted to know the brand. But thanks for the help
Old Nov 6, 2017 | 12:47 PM
There’s some many brand out there but the one Nissan uses is factory you can’t purchase it because the bulbs is built into the headlight assembly itself. You can purchase aftermarket led bulbs from Theretrofitsource.com. Or you can fork out a couple grand for a pair of oem led headlamp on Nissan estore. But you might have to do some hard wiring because the non-equip led model doesn’t have the direct wiring.
Old Nov 7, 2017 | 06:58 AM
Nissan's LED projectors are made by Koito.
Old Nov 8, 2017 | 01:31 PM
calabs's Avatar
I believe they are the same lights that are in the Rogue and Murano.
