Infiniti red sport rims
Old Jan 30, 2019 | 05:40 AM
MafiaGenius's Avatar
I'm looking to get some 20" Infiniti red sport rims. But I'm not 100 percent sure they will fit my 16 platinum came with the 18" rims which are 18x8.5 and the offset is 50. The Infiniti rims are 20x9 with a 40 offset. Any input would be appreciated. Also I'm looking at running 255 or 245 by 35 tires thanks
Old Jan 30, 2019 | 07:44 AM
MadMax07SL's Avatar
Pretty sure Red-sport have staggered rims...so you have 2 different sizes to consider here...
lindros2's Avatar
Like the staggered 20" from the Q60 (coupe) ?
Based on my experience with the 19" rims from the Q50 sedan, you would be out of your mind to put these on a Maxima.
And staggered wouldn't fit.
Old Jan 30, 2019 | 01:55 PM
kasdepwel's Avatar
Check for stagger. I run 20x9.5 40 offset and it’s perfect.
Old Jan 30, 2019 | 08:56 PM
They are 9" all the way around. Rims no tires.
Old Jan 30, 2019 | 08:57 PM
Can you post a pic of your car? What size tires are you running?
Old Jan 30, 2019 | 09:00 PM
why would I be out of my mind to run 20x9 Rims on the car?
Old Jan 30, 2019 | 11:02 PM
MONTE 01&97 SE's Avatar
Only the Rwd has staggered rim sizes, if you can get them from an AWD RS400 they are all the same size on all 4 corners!
Old Jan 30, 2019 | 11:28 PM
that's what the seller told me they are off a awd from NYC. Car went from the dealer to the rim shop.
Old Jan 31, 2019 | 05:31 AM
lindros2's Avatar
Weight, drag on transmission, car not designed for it, and my personal experience with the 19" red rims (standard on Plat Reserve) that feel like a complete mis-fit.
Old Jan 31, 2019 | 05:48 AM
kasdepwel's Avatar
That is not true, first weight is very close from 20" to 19", my OEM SR wheel were 25 pounds, my 20s are 24 pounds. Car not designed for it is nonsense, do not spread misinformation. If you get a decent tire for the 20s, it'll run smooth enough for daily driving.
Old Jan 31, 2019 | 07:00 AM
robtroxel's Avatar
You totally forget about the offset which if out of kilter will cause premature wheel bearing failure and poor handling. A 20 inch wheel on these cars usually means a rubber band side walls aspect ratio (35 or 30). Might as well buy extra wheels and tires to replace what you will destroy in the roads we have in the midwest.
Old Jan 31, 2019 | 07:23 AM
kasdepwel's Avatar
yes of course offset plays a factor for bearings but not in a 40 offset. It’s too marginal of a change. As for tires you must not cheap on tires for comfort on a 35 sidewall.
Old Jan 31, 2019 | 03:24 PM
lindros2's Avatar
With the Maxima, I don't think there will be any semblance of "comfort" moving to 35 sidewall.
After owning a number of BMW with 19" alloy wheel rims, I'm surprised at what a (jarring) difference 45R18 > 40R19 made...
Heck, this is even worse than my GT-R with 20" wheels (rims).
Tonyblock
Oct 22, 2013 09:51 AM
x2dus
Feb 13, 2010 02:40 PM
mdma
Nov 1, 2005 11:00 PM
xtatic one
Tires and Wheels
Mar 5, 2004 09:54 PM
