| 240tomax |
Jan 13, 2020 05:10 PM |
Driver door won't open
The temperature dropped over night in my region going from approximately 32 degrees to 8 degrees. I park my Maxima in a garage at home so the issue began when I entered my Max after work where it sat there for 7 hours in 8 -10 degree weather. I was able to open the door but it took a couple of times to close the door from inside the car. When i arrived home, a short drive of 10 minutes the door would not open. The door actuator appears to be working properly as from the inside it moves when it is locked or unlocked. I can not open it from the inside or outside. Searching previous posts on the forum indicates that this is somewhat of a problem in cold weather and seems to clear up when it warms. Is this true? What has been the actual problem? Any insight would be greatly appreciated.
