Leaking Half Shaft
Old Apr 6, 2020 | 01:35 PM
airic331's Avatar
Leaking Half Shaft
I was installing new brake pads in my Maxima and noticed where the left side half shaft connects to the CVT is a bit wet; please see pictures. Nothing on top appears to be leaking down towards this area so I have to assume there is a slow leak in the seal. I have a 2017 with only 22,000 miles on it. Has anyone noticed anything similar to this?
Old Apr 6, 2020 | 07:21 PM
compyelc4's Avatar
This is a seep, not a leak. I would not worry about it too much. If it were mine, and out of warranty like yours and mine, I would just spray the area off with parts cleaner, dry things up and watch it for a month. I'll bet that seep does not return for many miles. Just keep an eye on it. I check for leaks like this at each oil change I do.
Basic Drivetrain Warranty: The engine, transmission, transaxle and drivetrain are all covered; 36 mo. or 36,000 miles.
Old Apr 7, 2020 | 02:11 AM
RickSmith's Avatar
You may want to revise your comment after reading the warranty booklet, as your comment is not totally correct. Pay close attention to page 6.
https://owners.nissanusa.com/content...ty-booklet.pdf
Old Apr 7, 2020 | 07:11 AM
compyelc4's Avatar
60 mo. or 60,000 miles! I stand partially corrected, and I am very pleased to correct the info I gave. Gives me some comfort too.
From THE BOOK: "TRANSMISSION AND TRANSAXLE Case and all internal parts, torque converter and converter housing, automatic transmission control module, transfer case and all internal parts, seals and gaskets, clutch cover and housing, A/T cooler, and electronic transmission controls. DRIVETRAIN Drive shafts, final drive housing, and all internal parts, propeller shafts, universal joints, bearings, seals and gaskets."
Old Apr 7, 2020 | 07:24 AM
robtroxel's Avatar
Thanks to both Compyelc and Rick Smith for the discussion. This is indeed good news for the OP. I would take it in sooner than later.
Old Apr 7, 2020 | 10:11 AM
2young2retire's Avatar
Brake pads at 22,000 miles?
Old Apr 8, 2020 | 07:54 AM
robtroxel's Avatar
Not uncommon given the driving techniques I see daily, zooming from one stop light to the next. So much for energy management! I can easily get 60,000 miles on a set of Maxima brakes.
Old Apr 8, 2020 | 08:52 AM
I agree. I changed the pads on my 2009 Maxima at 100,000 miles and they still were serviceable. However the jury is still out on the longevity of the pads on my 2017. The automatic braking when using the cruise control and during other situations may result with shortened pad life. Time will tell.
Old Apr 13, 2020 | 02:04 PM
airic331's Avatar
I decided to upgrade to Powerstop ceramic pads as the amount of brake dust coming off of the stock pads was beginning to annoy me. If anyone wants the stock front brake pads with tons of life on them, lmk I'll let them go for cheap.
Old Apr 13, 2020 | 02:06 PM
airic331's Avatar
Thanks for looking this up Rick! Puts my mind to ease knowing this information. I'll still take it in soon and see what the techs say about it.
Wolcottmax1
Sep 27, 2016 06:11 PM
IMAdamtotheMax
Advance Paint and Body Work
Feb 18, 2013 06:02 PM
JRS89MAX
Mar 11, 2012 03:09 PM
tallica62
24
Feb 18, 2005 07:05 AM
