Tune up for 2016 Maxima
Old Sep 17, 2021 | 09:03 AM
MrDillons's Avatar
Hello Everyone,
I am getting ready to do a tune up on my 16 Maxima and I just wanted to know if I'm missing something. I'm def a former Acura/Honda dude, so I'm well experienced with tune ups for those cars, but this is my first Nissan and I discovered there is a timing chain. So can someone tell me what are items I would need to complete this task. I have the water pump, spark plugs, coils for the plugs. What else will I need? I searched extensively for this before I posted, I didn't see anything in the 8th Generation Thread.
thanks you
Old Sep 17, 2021 | 09:17 AM
RA030726's Avatar
I'm nutty for Nissans
How many miles are on the car now?
Old Sep 17, 2021 | 05:57 PM
MrDillons's Avatar
133,000
Old Sep 18, 2021 | 06:42 AM
RA030726's Avatar
I don't think you should mess with the water pump.
Coil packs? Maybe.
Fluids and filters, spark plugs, any gaskets on the intake you remove, clean the throttle body and mass air flow sensor.
Old Sep 18, 2021 | 09:22 AM
robtroxel's Avatar
Coil packs? Maybe.
Disagree in >>that if you change the serpentine external belt> which you should>>the water pump will fail soon after because the tightness of the belt will be different on the water pump shaft. Also, replace the tensioner pulley while you are at it and flush the system. New antifreeze rounds out this task. At 133 K you might as well.
Old Sep 18, 2021 | 10:17 AM
RickSmith's Avatar
2016 Maxima 3.5 water pump is not driven by the serpentine belt, is is driven by the timing chain.
​​​​​​https://www.1aauto.com/nissan-infini...caAvOdEALw_wcB
Old Sep 18, 2021 | 12:58 PM
RA030726's Avatar
That's not how our cars work so WTF?!?!?!?
BUT yes, a new serp belt and tensioner is not a bad idea.
Old Sep 19, 2021 | 05:50 AM
robtroxel's Avatar
Thanks Rick,
The water pump drive off the timing chain is a plus so I correct my earlier suggestion. Still, at 133 K miles, I'd change out the serpentine belt and its tensioner pulley and flush the and replace the antifreeze.
Old Sep 27, 2021 | 04:59 PM
MrDillons's Avatar
Thank you Everyone, for all of your suggestions. This is my first Nissan and its a lot different than Honda. I will be replacing all of this and do shocks and tires next.
Old Sep 28, 2021 | 05:34 AM
robtroxel's Avatar
Keep us posted on the work as you do it and the condition of the parts removed. Good luck
icewake
Feb 13, 2006 10:25 AM
MY2000MAX
Oct 14, 2004 11:56 AM
fusionx21
Sep 3, 2004 01:38 PM
