Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
K-Sport Coilovers Talk
Old Aug 17, 2005 | 06:43 PM
  #281
jsmithsole's Avatar
*moderator*
OK everybody. I just read all 280 posts on this thread and I have learned alot thanks to all. I just had my Ksports installed on my 2004 today and it is stiff, I mean really stiff. It feels like there is no travel whatsoever front or rear. I took it to a reputable place that knows what they are doing, or so I thought! They did not adjust the height and left it a bit higher than my car sat with the Eibachs on, I'm going back tomorrow to adjust everything.
I just would like some guidance on what to ask/tell the guys when I take it back to the shop tomorrow. I am assuming that they just preloaded the springs too much?
ANY FEEDBACK WOULD BE HELPFUL, AND THANKS FOR ALL THE GREAT INFO...
Old Aug 17, 2005 | 08:18 PM
  #282
djfrestyl's Avatar
Suspension Yoda
Give it just a bit of time for them to settle. I noticed that the first day or two of riding on them, they were very bouncy and stiff. They settled a bit after that.
Old Aug 17, 2005 | 08:44 PM
  #283
jsmithsole's Avatar
*moderator*
Are you sure it's correct to have absolutley no travel at all? Just doesn't seem right. I could see if it were just stiff, but this makes me wonder.
I also noticed that they have left my eibach springs in with the rear coilovers? Now again please don't bust my *****, this is completely new to me, but that can't be right??? Right?
I just want some solid info to tell these guys tomorrow because I'm getting the feeling they might be as lost (OK maybe not as lost) as me...
Thanks again...
Old Aug 17, 2005 | 08:52 PM
  #284
djfrestyl's Avatar
Suspension Yoda
Wow I just blazed through your post too fast.
I HIGHLY doubt that your Eibach's should be in the rears, you should keep the springs that CAME with the coilovers, first of all.
Second of all, as far as travel is concerned. The rule of thumb we have been going by is to load the bottom perch of the spring just enough so it holds the spring in place, but not too much that it compresses it. (This is done, of course, when the car is off the ground) That will ensure the correct amount of travel.
Old Aug 18, 2005 | 04:30 AM
  #285
d00df00d's Avatar
Old enuf to pick his own gears
@ the preload rule. That's basically gospel. Also, you're supposed to adjust height by changing the position of the lower mounts. Make sure your shop uses that, and not preload.
Keep in mind that when you're sittin' on 20s, you'll feel a stiff suspension a lot more. It's all about unsprung weight, and you have a lot of it. Once things are in order and you can be sure your preload is where it's supposed to be, how it rides then is going to be as smooth as it gets on those rims.
As far as having your Eibachs in the rear... how can you tell? Do you see the little "Eibach" logo on them, or are they progressive-rate? I wouldn't even think the Eibachs would fit in there. The shop would have had to disassemble your rears to put them in anyway... it's just more work for them. But if they actually did do that without telling you, get an explanation and be ready to roll some heads cuz that is really not cool.
Good luck, man. Welcome to the world of low cars and semi-real handling.
Old Aug 18, 2005 | 05:52 AM
  #286
jsmithsole's Avatar
*moderator*
You guys rock!! Thanks for the solid info. I feel good now to go talk to them and feel like I 1/2 way know what I am talking about!!
Old Aug 18, 2005 | 07:26 AM
  #287
jsmithsole's Avatar
*moderator*
So I looked under the car again and the coilover is installed and there is still a spring seperate from the complete coilover. Shouldn't the old spring be removed from the control arm completely and the entire coilover is mounted where the shock mounts?
Here's a pic:
Again thanks for the help!!
Old Aug 18, 2005 | 08:03 AM
  #288
djfrestyl's Avatar
Suspension Yoda
WHAT THE HELL?!
if the correct coilover spring is IN the coilover, that spring shouldn't be there, in fact, that spring should not be there in any case.
yes, the old spring/strut combo gets REMOVED and the new coilover (spring/strut) assembly replaces it and uses the same bolt points that the old one did.
who the hell did your work?
Old Aug 18, 2005 | 08:41 AM
  #289
jsmithsole's Avatar
*moderator*
WHAT THE HELL?!
Thought so, I am going to raise hell with these guys today!!
Thanks!
Old Aug 18, 2005 | 08:43 AM
  #290
djfrestyl's Avatar
Suspension Yoda
Also, it's quite possible thats why your ride is SO stiff, you're running two sets of springs
Old Aug 18, 2005 | 08:56 AM
  #291
NOZMaximus's Avatar
What in gods name is going on there??? How did they bolt that setup in there?? Take more pics, this is beyond wierd.
Old Aug 18, 2005 | 09:48 AM
  #292
blazingchimp's Avatar
wtf... i mean i dunno what a 6th gen suspension is supposed to look like but that cant be right....
Old Aug 18, 2005 | 10:14 AM
  #293
d00df00d's Avatar
I get it now.
Holy freakin' crap. That is the dumbest thing I've seen so far today. And I had to drive through morning rush hour traffic in Philly this morning, so I've seen some pretty dumb things today.
It's not really unusual to have the spring separate from the shock in a suspension, especially in fully-independent suspensions. Apparently that's what the 6th gen's stock setup is, and obviously the shop concluded that the coilovers were only supposed to replace the shocks.
That makes them pretty clueless. They've probably never even seen aftermarket coilovers before, and either way they don't seem to know much about suspension.
In other words, nothing's wrong with the car, but the shop's competence is... in doubt.
Old Aug 18, 2005 | 10:39 AM
  #294
NOZMaximus's Avatar
If that were the case, then wouldn't k-sport have shipped the spring and CO strut assembly separate from each other since they are not to be mounted together??
Old Aug 18, 2005 | 11:33 AM
  #295
d00df00d's Avatar
No, because then they wouldn't be coilovers.
Separate mounting for the spring and shock can give you more flexibility in designing the suspension on a budget (any budget at all... not saying the car is cheap). It's not the way the car absolutely has to be... it's just a design choice that the Nissan engineers made.
In order to have adjustable height and preload, you need the spring and shock in one assembly. Otherwise you'd have to replace a lot more parts in the suspension besides the springs and shocks.
EDIT:
You know what, though... I'm starting to think that with coilovers, you'd be focusing all the stress on the strut mounting point, whereas in the stock suspension it's at least distributed between the spring mount and the shock mount. This bears further consideration...
Anyone care to furnish pics of the 6th gen's suspension, showing the mounting points for the shocks?
Old Aug 18, 2005 | 11:45 AM
  #296
NOZMaximus's Avatar
Ah, so then all the shop really needs to do is remove the stock springs, correct?
Old Aug 18, 2005 | 12:21 PM
  #297
jsmithsole's Avatar
*moderator*
I called and gave them a bit of hell!! I asked if they had ever installed a coilover kit and they said they have, in fact a friend had his installed there? Anyways I'm going down there this afternoon with much more knowledge than I had yesterday thanks to you guys and this thread!! Wish me luck...
Old Aug 18, 2005 | 01:17 PM
  #298
d00df00d's Avatar
Yup.
Gah... you know, if I were super painfully hugely rich, I would buy a 6th gen just to turn it into a total track ***** and start tinkering with double-spring setups. The possibilities would be limitless!
Old Aug 18, 2005 | 04:04 PM
  #299
max929's Avatar
Can the camber from a drop be adjusted without using the Plates???? How?????
Old Aug 18, 2005 | 06:09 PM
  #300
jsmithsole's Avatar
*moderator*
OK, everything is all good now. They had some rookie guy that didn't know to remove the spring since it is seperate on the 6th gen. Anyways they removed the springs and the rear is fine, a bit stiff still but I imagine the break in time will handle that.
As for the front they did preload the springs too much, all is good now.There was another guy at the shop that wasn't there yesterday that knew exactly what was going on, he was giving the installer a pretty hard time about it all...
Here's a pic:
Thank again to all for the help on this, I felt like such a newb!!!
Old Aug 18, 2005 | 09:16 PM
  #301
Black Maxima
Can someone make a write up on how to adjust the ride height and camber plates once the coilovers are installed on the car? I know how to install the strut, I just don't know what I will be turning or not turning once it's on there. A picture explaining each part would be very cool.
Thank you!
Aaron
Old Aug 19, 2005 | 07:24 AM
  #302
d00df00d's Avatar
Adjusting the camber plates is easy. Just find an allen wrench of the appropriate size, jack the car up, loosen the 4 screws, and move the whole thing by the top bolt to adjust. If you need to adjust it past what it allows, you can move two of the screws to the center holes.
Adjusting the ride height once the coilovers are installed shouldn't really be possible, unless you use the preload/spring position to do it. You would adjust that by moving the lower spring perches: jack the car up, move the spring perch up or down, and when you put the car back on the ground, the car will settle to its new height. That's not necessarily the best way to do it, though. It should be okay for fine-tuning, but lowering it too much by just moving the spring down could shorten the life of the shocks because they'll be constantly pre-compressed. Raising it by adding preload will make your ride *really* stiff.
Large height adjustments are supposed to be made by changing the positions of the lower mounts before you install the coilovers on the car.
Old Aug 19, 2005 | 07:27 AM
  #303
d00df00d's Avatar
Adjusting toe will also affect camber, but that'd be a terrible way to do it. So really, the answer is "no".
Old Aug 19, 2005 | 08:25 AM
  #304
Tommy Boy's Avatar
The K-sports have a seperate height and spring preload adjustments! You can raise or lower your vehicle height without changeing your spring height or spring preload. A word of caution. I have my car set at just about full height on the coiovers and that is still about a 1-1/4" drop front and 1-1/2" drop rear. This leaves me with about a finger and a half worth of gap between tire and fender.
Black Maxima: If you want to take a ride up to Rocky Hill I'll show you my setup and how to adjust them.
Old Aug 19, 2005 | 08:46 AM
  #305
d00df00d's Avatar
I'm aware. You just can't really make that adjustment with the coilovers installed, which was what I was saying.
Old Aug 19, 2005 | 09:39 AM
  #306
Tommy Boy's Avatar
You're right. There is no simple way to screw it up or down once installed. You need to remove the two spindle bolts and screw the body up or down then reassemble and check height. It is a PITA, especially if you are trying to get the car level side to side, but not imposssible. It just takes time and patience!
Old Aug 19, 2005 | 08:24 PM
  #307
rush0's Avatar
Man, I really have to say thanks to d00df00d, I took alllll the preload off the springs, and what a difference, I mean holy poo, I am on 18's, 40 series bald crappy tires. And the ride is so dandy, its only bad when you go over bumps slow, These coils can handle NY roads if adjusted right, i'm sure more adjusting will make them ride even better. and handling is bad *** of course =D, thanks again.
Old Aug 19, 2005 | 09:19 PM
  #308
Black Maxima
Thanks for the replies. It looks like there are a lot of adjustments I can make on these coilovers. First of all maybe I should get some of the definitions down. What is preload?
Tommy Boy - You have a PM!
Old Aug 19, 2005 | 09:40 PM
  #309
jinsu's Avatar
preload is when you tight down both the top and bottom lock nut of the springs and compress the springs. By doing this you will increase the spring rate of the kit.
Old Aug 19, 2005 | 09:47 PM
  #310
Black Maxima
Good answer. I understand that. Now what needs to be adjusted so my wheel gap decreases?
Old Aug 19, 2005 | 11:10 PM
  #311
Mr.Duck's Avatar
When you get your coilovers you will see that on the bottom of the strut can be turned, it will raise and lower the car by shortening the strut, but it will not affect the travel what so ever. Shortening your springs will affect the travel because there will be preload on it. It took me about a week to adjust the ride height, and is till dont have it right, just havnt had time to raise my back end. It is a pain the *** to adjust the ride height after installing the coilovers, and you need a lot of patience. so be ready
Old Aug 20, 2005 | 08:24 AM
  #312
Black Maxima
The big orange pieces on the bottom of the strut? I guess the strut mounts are the pieces that you turn to adjust the height? I'll find out today, I'm meeting up with someone...
Old Aug 20, 2005 | 01:05 PM
  #313
snakebyt's Avatar
What is everybody doing about brake brackets for the front brakes? I've seen a few people asking about them in earlier post, but I haven't seen a reply as to where to get them. The brake lines hanging down on the axle can't be good.
Old Aug 20, 2005 | 05:29 PM
  #314
d00df00d's Avatar
Yup, that's them.
Those thin black wrench-looking things that come with the kit are the brake line brackets. It seems some people are using them and some are just using zip ties to tie the lines out of the way.
Old Aug 20, 2005 | 07:09 PM
  #315
snakebyt's Avatar
Ok, thanks for the quick reply. I just put mine on today, I need an alignment but the ride quality good. Better than I expected after hearing people talk about coilovers being really stiff and bouncy.
Old Aug 20, 2005 | 07:24 PM
  #316
nismology's Avatar
Why is it that people impulsively go get an alignment after a car is lowered? I've done suspension work on cars that had perfect alignment before and after being lowered. I don't see how the alignment would be changed if you dont mess with the tie-rod ends. Can someone please explain this.......?
Old Aug 20, 2005 | 07:36 PM
  #317
upstatemax's Avatar
Originally Posted by nismology
Why is it that people compulsively go get an alignment after a car is lowered? I've done suspension work on cars that had perfect alignment before and after being lowered. I don't see how the alignment would be changed if you dont mess with the tie-rod ends. Can someone please explain this.......?
the alignment was fine... I just needed to have the camber set.
Old Aug 21, 2005 | 06:21 PM
  #318
d00df00d's Avatar
Well, with this particular set, there are two factors. The biggest is that the strut bolt holes on each strut mount are not both circular. The top ones are ovals, which permits some variability in the angle the struts make when they attach to the spindle. The other factor is imprecision in setting the positions of the bottom mounts.
Old Aug 23, 2005 | 03:38 PM
  #319
max929's Avatar
WOW, I used the camber plates after dropping the car about 2 1/2 inches in front and a inch and 1/4 in back and my tow was scary OFF... Had an alignment done today and the mechanic didn't understand how I was able to drive it. Tow was corrected, camber is near spec, love the ride. Word to the wise, if u plan on adjusting the camber plates get an alignment after wards or alot to strengthen your arms......
Old Aug 23, 2005 | 09:23 PM
  #320
Matt93SE's Avatar
STFU n00b!
It's because your alignment changes with ride height. every car has a small amount of bump steer in the chassis, and when you lower it, it gets worse.
