Q45 Caliper/13'' Cobra Rotor BBK Upgrade Write Up
For those who have done the Q45 caliper install with Jeff's brackets and the Cobra Rotors, I would be interested to know what wheel clearance you all have. I want to upgrade to the 13" BBK but I don't want to use spacers with my I35 Sport 6-Spoke 17"x7" wheels. Anyone else have wheels like this with a BBK installed? Let me know.
Thanks.
-Mrkanda
Thanks.
-Mrkanda
Well you have to imagine the new placement of the caliper after the bracket is installed. ie.. about 2-3" out towards the id of the wheel. Also the brackets will move the caliper OUT about 10mm. So if you have more than 10mm of clearance now (but where the caliper WILL be), you stand a good chance at clearing.
A picture would help
It appears that Automax (IIRC) is selling pre-drilled rotors so the rings aren't necessary. Has anyone installed them on their car yet? My rings seem to have fallen off the face of the earth and I would like rotors that fit properly, so I'm thinking of getting the pre-drilled rotors. Any thoughts?
Automax has been selling the pre-drilled versions for a few years now. I haven't read/heard of any complaints yet. You could try to get your existing ones redrilled if yours are still in good enough shape to justify the costs.
I believe the 350Z 17s will work. But I don't have a pic to prove it. But I do know 350Z 18s/coupe 18s/coupe 19s/350z track 18s and the 17" 1997 Ford cobra wheels will clear. Because that's what I've run.
Apr 16, 2020 05:15 AM
