Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Ground controls and spring isolators (4th gen)?
Old Jun 16, 2006 | 06:36 AM
cardana24's Avatar
Blown
I have ground controls on my my 95 and I was getting noise from the rears. So I looked into it last night. My problem is coming from the upper spring perch pushing thru the isolator (thick rubber peice) and then I get a rubber squeeking noise. Does anyone have experience with this? I actually have been very happy with the ground controls so far as far as drop/handeling/noise and would like to get this figured out. The other twist that I have thrown into this is that I am using Ben's rear long travel mounts so the isolator is free to slide around since there is not a groove for it to sit in. I am thinking I need to make custom isolators. Does anyone know where I can buy thick enough rubber to make isolators? Or has anyone sucessfully corrected this problem. Thanks for any suggestions.
Old Jun 16, 2006 | 09:04 AM
Cutler's Avatar
remove the rear mounts and see what happens. If the noise goes away then you have found your issue....
Old Jun 16, 2006 | 10:06 AM
cardana24's Avatar
Blown
I want the long travel mounts so I am looking to fix it with the mounts. I know what the problem is so I would like to find a soulution with out removing them.
Old Jun 18, 2006 | 02:12 PM
Matt93SE's Avatar
STFU n00b!
have the long travel mounts machined with grooves for the perch in it.
sounds easy enough to me.
Old Jun 18, 2006 | 05:16 PM
cardana24's Avatar
Blown
I think they are too thin for that. Basically the top of the pearch has a hump in it so that it will fit into the stock mount. A groove would not hold it. Plus the isolator is still too big so the pearch is still going to push thru it.
Old Jun 19, 2006 | 07:03 AM
Matt93SE's Avatar
STFU n00b!
Then you either need to have the right parts machined or take them off completely. round plug, square hole.
Old Jun 19, 2006 | 08:37 AM
cardana24's Avatar
Blown
why not just make a rubber isolator that actually fits?
Old Jul 1, 2006 | 05:06 AM
Stillen Maxima's Avatar
Pay to Play
True, i was thinking the same thing!
Old Jul 1, 2006 | 06:59 AM
RA030726's Avatar
I'm nutty for Nissans
Can you post a pic? I have bens mounts, CG's, and while they are not on the car they seem like I put them together well. I dont think there will be any noises. I dont remember the exact order of parts, but there is a bunch of rubber bushings all over between the metals.
Old Jul 2, 2006 | 08:06 PM
cardana24's Avatar
Blown
I already returned them to the stock rear mounts so I cannot post a pic. But when you have the ready to go on the car you will see what I am talking about. The upper spring perch for the ground controls is about the same diameter as the inside diameter of the stock spring isolator so with the wight of the car on it, it pushes thru. I returned mine to the stock mounts and I have no noise so I am happy. Currently I am running the GC's with AGX's and I am very happy with the ride quality and the lack of noise. I used the write up that was done on the 200sx, with the duct tape and silicone, and not using the rubber spacers, and I am very happy.
stevesmax
Dec 17, 2020 11:57 AM
Finkle
Sep 27, 2015 09:53 PM
homeyclaus
Sep 3, 2015 06:15 PM
