Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Where does the Front Lower Subframe Bushing Set install?
Old Aug 6, 2006 | 05:34 PM
Nealoc187's Avatar
SLOW
I'm ordering a full set of ES bushings from suspension.com and they've got a bushing listed that I've not heard of, nor can I find a diagram for.
Front Lower Subframe Bushing Set - part # 7.1116
I don't want to spend $23 on this if it's something that is damn near impossible to install and you have to rip the entire car apart to do it.
Anyone have a pic, diagram, or can describe where this bushing set installs? I've not gotten under the car to go poking around yet, as it is dark outside.
Old Aug 6, 2006 | 06:20 PM
BEJAY1's Avatar
Conecarver
Neal, it's an easy install. Support the engine, drop the crossmember, replace bushings, install. PM me your e-mail - I've got the whole instruction sheet in PDF I can send. Brian
Old Aug 6, 2006 | 07:39 PM
irish44j's Avatar
retired moderator
Brian, your thoughts on it being "worth it".....
btw, did you ever finish designing those new pillowball mounts for the camber plates? Ironically, mine are now making noise at the upper mount not 2 days after I was saying how great and quiet they were
Old Aug 7, 2006 | 03:16 AM
Puppetmaster's Avatar
Yup, its an easy install (but I've yet to do it). Polo had some pics here:
http://www.digitalpolo.com/2002Maxim...frameBushings/
Old Aug 7, 2006 | 04:06 AM
BEJAY1's Avatar
Conecarver
I put the subframe bushings in the same catagory as the RSB. It won't hurt to install it so why not. And no, I never did anything with the pillowballs yet. Parts are still sitting around here like so many projects left undone. I'll get to em this winter as I now have a plan in my mind for the '07 & '08 seasons.
Old Aug 7, 2006 | 06:01 AM
97SEdriver's Avatar
this place is dead
um.....what was that? Say again?
Old Aug 7, 2006 | 06:42 AM
Larrio Motors's Avatar
Boss Chen Industries
I think they should be listed as crossmember bushings to be more accurate
Old Aug 7, 2006 | 06:50 AM
Old Aug 7, 2006 | 06:53 AM
front lower subframe bushings are made by ME.
Stay tuned.
Old Aug 7, 2006 | 07:03 AM
DrKlop's Avatar
Driving is the next best thing
I have those so-called [not real] subframe bushings and I don't feel any difference. However, I think it will be an affective mod if you will also get ES motor mounts.
BTW, installation is VERY easy! Just don't forget to place a jack under the crossmember or the whole thing might simply fall out of there.
Old Aug 7, 2006 | 08:35 PM
Nealoc187's Avatar
SLOW
OK guys cool. I just didn't know what part they were actually referring to when they called them "front lower subframe bushings." Had they said "crossmember bushings" it would have been immediately obvious to me... I can have the crossmember out in like 5 minutes lol I have lots of practice. I'll definately be purchasing them now that I know what they are, the stock bushings that go there are JACKED on my car.
All new bushings and ball joints should really tighten up the sloppy front end of this car. I've already got ES motor mounts.
Old Jun 20, 2011 | 07:29 PM
Totalpckge1's Avatar
What do these bushings do?
homeyclaus
Sep 3, 2015 06:15 PM
soon2ownmax
Aug 13, 2015 02:19 PM
Team STILLEN
Aug 10, 2015 04:29 PM
