Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
parts that can be re-used when working on suspension
Old Aug 22, 2006 | 05:13 PM
kbmaxima's Avatar
i'm going down the list on http://staff.jccc.net/dlee/maxima/suspension/ and i know i can probably re-use the spacers and can definitely re-use the brackets. anything rubber I will replace, however the insulator strut, part# 54320-40U00 which lists for about $40 a piece is skewing the budget. can those be re-used?
http://staff.jccc.net/dlee/maxima/su...n/061002-7.JPG
Old Aug 22, 2006 | 06:00 PM
irish44j's Avatar
retired moderator
yes, the upper strut components can all be re-used (bracket, rubber seat, strut isolator, etc).... Just make sure to check them for any unusual wear. Pay particular attention to the plastic "strut bearing" that sits between the upper spring perch and the upper mount and make sure that it hasn't cracked.
Replacing the upper nuts is not a bad idea, but certainly not required.
Old Aug 22, 2006 | 06:13 PM
kbmaxima's Avatar
thanks irish. man i'm compiling everything suspension wise. i'm just missing the rear mounts that ben used to make. is it ridiculous that i'm changing control arms, inner/outer tierods, swaybar endlinks and bushings, strut bearings, mounts, etc. i just wanna get this done once and enjoy it for the rest of my car's life. while i'm here, if any north jersey/nyc people are reading this. would u like to help me with my suspension project? food+beer+gas money
Old Aug 22, 2006 | 06:46 PM
crazy97's Avatar
Irish44j-
Was it you that stripped the upper nuts while properly usung a torque wrench a long time ago?
Old Aug 22, 2006 | 06:51 PM
kbmaxima's Avatar
how old is that parts list?? i put those into the jrnissan site and i'm coming back with parts for 04-06 pathfinders for the strut bearing, 54325-5V000. plus i cant find the spring isolators for the rears
Old Aug 22, 2006 | 06:59 PM
irish44j's Avatar
retired moderator
screw that online crap. Call DaveB. He'll find what you need and give you the best prices on them. I'm sure he'll also be happy to talk to you about what you should and should not replace....
Crazy97 - I don't remember stripping the top nut on my car, but then again I've worked so much on it and stripped so many nuts and bolts on it, I may have just forgotten It might also have been on someone else's car I was helping with
maxinout93
Oct 27, 2015 01:29 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Team STILLEN
Aug 10, 2015 04:29 PM
kenc15
Aug 5, 2015 08:29 AM
