Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Rear strut bolt problems...HELP!!!!!!!!
Old Sep 25, 2006 | 07:41 PM
WhiteMaxima9600's Avatar
I put on my s-tech's today and when i was reinstalling the driver side rear the bolt that runs though the strut was extremely hard to turn, naturally the da** nut that is fixed to the piece strips out on me.... The bolt is at least 3/4 of the way tight but not fully.. It's so tight in fact that i cant even get it off!!
Any suggestions? Will it be ok like that? I can't even get it off so i don't see how it could come loose....
Old Sep 27, 2006 | 09:44 AM
d00df00d's Avatar
Old enuf to pick his own gears
Are you sure it's the nut that stripped?
Old Sep 27, 2006 | 10:21 AM
Gapp's Avatar
Had the same issue. I used a long pry bar to wedge in between the nut and the tab so the nut wouldn't turn as I tightened it. It sucks so I know how you feel. I finally got it snugged up. If worse comes to worse, cut the bolt off and buy some grade 8 hardware...
Old Oct 15, 2006 | 05:13 PM
NisTech's Avatar
you must have not started the threads right and stripped it. On top of the nut on the shock there's a little tab that you can lock a vice-grip on and tighten underneath with a wrench.
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Johnny9595
Sep 3, 2015 05:18 AM
MaxStock
Aug 14, 2015 09:59 PM
laparka66
Aug 6, 2015 09:36 AM
