Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
BBK options from wilwood for 4th gens
Old Sep 26, 2006 | 09:37 PM
VIP Maxima
i was just browsing wilwood's website for BBK and they have a coupla good options. the 4 piston one seems like a good deal and compareable to the 300zx setup but runs a bit more expensive. not to mention that the pad choices will be much better with the 300zx bbk setup. anyone tried the wilwood yet? your thoughts?
http://fastbrakes.com/shop/index.php?cPath=30_82
im sure we can use 13" rotors with these right ? they come with SS lines, pads, slotted and drilled with your choice of 4 piston or 6 piston calipers
Old Sep 27, 2006 | 02:04 PM
sciff5's Avatar
If you used the 300zx setup with the 13" cobra rotors or Matt blehms 2 piece rotors it will almost deff be more braking power than you need. Deff more braking power than the tires can provide grip on any sort of street tire.
Old Oct 4, 2006 | 06:11 AM
d00df00d's Avatar
Old enuf to pick his own gears
The thing about the Wilwood kits is that they are really lightweight, especially if you get 2-piece rotors. That's why they're more expensive than a Z32 setup.
AFAIK, everyone who's used one of their kits has loved it.
Old Oct 4, 2006 | 06:56 AM
MaximaSE96's Avatar
Maxima Owner
how much difference in wieght are we talking between Alum. Z32 calipers and 2 peice rotors and the wilwood 2 piece rotor kit
Old Oct 4, 2006 | 08:02 AM
d00df00d's Avatar
Could be ~20 lbs or more, IIRC... Don't quote me though.
Old Oct 4, 2006 | 08:24 AM
Chunger's Avatar
My other car is a Hybrid
they don't use these calipers anymore but you can look the new ones up on www.wilwood.com
Below are stock 4th gen...
Old Oct 4, 2006 | 12:47 PM
VIP Maxima
the wilwoods dont LOOK as good and you dont get as many choices for pads....
Old Oct 4, 2006 | 01:25 PM
Chunger's Avatar
Looks are up for debate (depending on model of Wilwood), but are you kidding about the choice of pads? Superlites or Dynalites were always listed from each HP brake pad manufacturer, and i'm not talking about over the counter variety too.
The Z calipers do have an outer dust seal... +1 for them.
Old Oct 4, 2006 | 01:33 PM
VIP Maxima
interesting, didnt know that.
would like to see some actual pics of the 4 piston caliper
Old Oct 4, 2006 | 02:29 PM
Chunger's Avatar
Not the one above? www.wilwood.com for their new selection.
The caliper below is no longer made...
Old Oct 4, 2006 | 04:46 PM
jaemax's Avatar
Fstbreaks full kit is approximately $900 however if you just buy everything but the rotors from Fastbreaks, for $600 or so and obtain the 04 rotors from Automax95 for $140... that is $740 for a nice setup... saving you roughly $160... I spoke with Brian myself and he recommened I go this route which is just as good...
jaemax's Avatar
Old Oct 4, 2006 | 04:51 PM
irish44j's Avatar
retired moderator
as to weight, I didn't weigh them, but the Z32 aluminum calipers are extremely light...I'd say 4 lbs tops.....
it's the rotors where the weight difference is more apparent in 1-pc vs. 2-pc
Old Oct 4, 2006 | 05:11 PM
sciff5's Avatar
As irish said the z32 calipers are aliminum and you can buy 2pc rotors which are prob just as light as the wilwood rotors if not less.
MAXSE5SPD
Sep 17, 2022 04:00 AM
9aj9
Apr 5, 2020 12:11 AM
BkGreen97
Apr 2, 2016 05:47 AM
I<3 A32's
Sep 10, 2015 11:07 AM
Lowered_a33
Sep 1, 2015 07:49 PM
