Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Bottom Scraping
Old Oct 8, 2006 | 04:41 PM
OmarBadu's Avatar
Bottom Scraping
6th gen - stock suspension
lately it seems like the bottom is scraping when I go over speed bumps - i hear what sounds like metal scraping when it's inbetween my front and rear wheels when - this sound didn't used to occur
overall the ride seems the same - there is no added weight in the car - is there anything that could be causing this that is screwed up with my suspension? any tests i can personally do or anything visually i can check? - i have little experience in this area
Old Oct 8, 2006 | 10:50 PM
!PrjctMax!'s Avatar
Is it coming from the rear? My best guess would be sway bar bushings/mounts. But your saying "metal scraping sound," so i'm not too sure. May also be blown struts, but once again that does not sound like scraping metal.
Maybe you're just dragging a piece of metal under your car?!
Old Oct 10, 2006 | 12:47 PM
OmarBadu's Avatar
the metal scraping sounds like the exhaust or something else under the car is scraping the speed bump - my car isn't lowered and speed bumps this is occuring on it didn't used to (and no i didn't gain an extra 100 lbs )
how do you check for blown struts?
Old Oct 19, 2006 | 05:21 PM
OmarBadu's Avatar
any ideas?
Old Oct 19, 2006 | 05:59 PM
irish44j's Avatar
retired moderator
check heat shields under the cat/exhaust. they sometimes come loose and make a scraping noise against the bottom of the car.
uttadms31
Sep 30, 2015 05:24 AM
jchronis2552
Sep 23, 2015 04:57 PM
95naSTA
Sep 21, 2015 06:50 PM
14GmMax
Sep 17, 2015 09:08 PM
Serotta33
Sep 17, 2015 12:14 PM
