Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
26mm 300zx calipers?
Old Oct 15, 2006 | 09:45 AM
Eyemfaster's Avatar
What all would i need for a brake swap on my 4th gen w/o ABS?
I'm considering picking up the calipers, so that's one thing off the list. Which rotors work with the 26mm aluminum calipers? And what else will I need?
From this site... http://www.mattblehm.com/300ZX_brakes.htm ...It looks like I will need some sort of rotors that will work with the 26mm calipers (idk what would work), some custom SS brake lines, relocation brackets, and misc hardware (like what?).
The kit from that site w/o rotors or calipers seems to be the best for my situation, as long as I can find rotors somewhere else. Is there anywhere else I can find this stuff for less $$$?
And does $120 seem like a good deal for the aluminum 26mm calipers, or is there something else i should be looking for (are the 30mm ones worth the extra money).
Old Oct 16, 2006 | 06:51 PM
z32drifter's Avatar
If you want to use the Z32 rotors, milled down to fit the 26mm calipers are fine. You can't run any of the other rotor combos with the 26s. For $120 I would keep looking for 30mm calipers.
I have the 26mm setup on my car, however I got the calipers and rotors free.
Old Oct 16, 2006 | 07:01 PM
irish44j's Avatar
retired moderator
Heck, for about $160 you can get remanufactured 30mm calipers with a 1 year warranty - the Aluminum ones from the 1991 Z:
http://www.autopartswarehouse.com
Old Oct 16, 2006 | 08:27 PM
happy4444's Avatar
160 each tho irish rite?
Old Oct 16, 2006 | 09:17 PM
Eyemfaster's Avatar
i can't find them on that site. where did you see them?
Old Oct 17, 2006 | 08:23 AM
oldngivout's Avatar
Willing to learn
Add in the $50 core charge on each caliper and the deal goes up by $100.
How do you get around that?
Old Oct 17, 2006 | 08:26 AM
MaximaSE96's Avatar
Maxima Owner
buy a beat up old set for cheap and return them as cores
Old Oct 17, 2006 | 10:26 AM
oldngivout's Avatar
Willing to learn
A beat up old set of 30mm cores - good luck finding that.
Even if you did, just put new seals in them yourself and save even more.
And you know the rebuilder can tell the difference in the 26 vs. 30, and they are holding your core charge hostage..................
Old Oct 17, 2006 | 10:41 AM
Dasyce's Avatar
wish these damn 26ers would work.
Old Oct 18, 2006 | 03:59 PM
Eyemfaster's Avatar
why don't they? can't you just do what they said up there ^ ?
Old Oct 23, 2006 | 06:05 AM
buttonhook's Avatar
I have a set of new 30mm z32tt caliper with pads for sale for $200+shipping the have been used for a total of 5 days!!
Old Oct 31, 2006 | 04:59 PM
ZIPPIN's Avatar
Mauja He Mauja
are they Aluminum
Old Nov 1, 2006 | 08:44 AM
buttonhook's Avatar
Originally Posted by ZIPPIN
are they Aluminum
no they are iron.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
beerman1378
Sep 8, 2015 02:19 PM
