Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
squeak going over curbs slowly?
Old Oct 25, 2006 | 12:03 PM
maximaownsyou's Avatar
i have a slight squeak when i go over curbs like backing out of my driveway, my car is dropped so i go over them slowly, this just started happening. i have tokico struts and progress drop springs only 6 months old on the struts and springs so i highly doubt its either of those. what if anything can i look at under the car to see where this might be coming from? any help is appreciated im totally lost on this one.
Old Oct 25, 2006 | 06:06 PM
The Law's Avatar
I R The Law
do you turn your steering wheel all the way and when going over the curb it makes the noise?
Old Oct 26, 2006 | 03:13 AM
yeah come to think of it i do think it is only when i have the wheel turned all the way
Old Oct 26, 2006 | 05:06 AM
Dasyce's Avatar
I get those squeaks all the time.
Old Oct 26, 2006 | 06:46 AM
Larrio Motors's Avatar
Boss Chen Industries
Most likely its from the stopper bolts that contact the control arm at full lock. When the suspension compresses on your lowered ride, the tip of that bolt is coming into contact with the control arm.
Just jack up your car, use a 17mm open ended wrench and take them off to see if the noise goes away. They are threaded into the bottom part of your hub.
Old Oct 26, 2006 | 07:42 AM
The Law's Avatar
I R The Law
Yep, larrio said the same thing that i was going to point out. As this happens to me to cause there is suppose to be a plastic cap thats suppose to be on there but it usually falls off due to wear and tear. I have the part number if you want it.
Old Oct 26, 2006 | 09:59 AM
hmm, so no damage is being done just a bolt contacting something. thats a relief i thought something was broken under the car. that takes 1 problem off my list..heh
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
