Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
powdercoating claipers
Old Jan 2, 2007 | 03:03 PM
SurraTT's Avatar
HR Swap Pioneer
well i picked up a set of z32 allum calipers from the yard
today i took em apart, they seemed ok, but ima get a seal kit
anyway, the NISSAN logo is messed up on both of them, im going to shave it, and get them powercoard RED
i want to get NISSAN back on there,
#1 get it painted on, and clearcoat the whole caliper
#2 get a sticker, then clearcoat over it
idk which one to do
Old Jan 2, 2007 | 11:32 PM
natty99's Avatar
i'd get it painted on, but it might be easier and cheaper to get a sticker.....if you're going to powedercoat them, I think you need a mylar sticker unless the vinyl is some high-temp variety.
Old Jan 3, 2007 | 06:55 PM
SurraTT's Avatar
HR Swap Pioneer
ok well now i got a problem
i ordered a new seal set
only thing is, there is a small oring inbetween the caliper peices , where the fluid travles side to side
the dealer has no way of getting it, unless i get a whole caliper
HAS ANYONE got anyof these????
here is a pic
http://surrattracing.com/oring.JPG
i have it sitting over the bolt hole
its not a typical o ring, it has flat edges, also a rugular o ring will get eatten up by the fluid
HELP please i need 4 of these bad
Old Jan 4, 2007 | 01:34 AM
natty99's Avatar
i think there was a post about this a while back, some guy had the same inquiry and problem....IIRC, they couldn't be bought by the dealer, as you've discovered and I don't think he had any success getting some. BUT, maybe you can google a few brake remanufacturers out there and see if you can buy some from them. That's the only thing I can think of. Or, just sell those calipers and actually get a better set, esp one with the NISSAN lettering intact.
There is another method but I am in no way condoning this; use your own metric of ethics to sort out if you can and will do this: A friend of mine had a similar problem and ended up buying the caliper from the dealer, opened up the caliper, took the O-ring out and closed the caliper back up...and yes, he returned it to the dealer for a refund, without the dealer knowing any better. I think that's pretty messed up, but hey people find ways around things.
Good luck
Old Jan 4, 2007 | 08:12 AM
Dubbya's Avatar
VK56 Inside
You wont be able to find the O-ring. Technically you arent supposed to break the calipers in half like that. I would reassemble them and trade them in on new refurbs from autozone.
Old Jan 5, 2007 | 09:11 AM
MaximaSE96's Avatar
Maxima Owner
who is doing ur coating...cause ill do it cheaper......to do the sticker under the clear the sticker will have to stand up to oven heat which it should....i would do it under.....pics of calipers in question
and yea u dont need to separate the calipers..
Old Jan 5, 2007 | 11:03 AM
SurraTT's Avatar
HR Swap Pioneer
they told me $20 a caliper
to late its taken apart
Old Jan 5, 2007 | 01:26 PM
MaximaSE96's Avatar
Maxima Owner
for rebuild kit or powdercoating......$20 sounds right for the rebuild....u can get it from rockauto.com
Old Jan 5, 2007 | 06:25 PM
SurraTT's Avatar
HR Swap Pioneer
powercoat
rebuild kit was like $10 for seals no pistons
Old Jan 5, 2007 | 07:05 PM
MaximaSE96's Avatar
Maxima Owner
are u doing all the prep work on the calipers before they are coated
Old Jan 5, 2007 | 07:54 PM
SurraTT's Avatar
HR Swap Pioneer
as far as cleaning n stuff yes
im not taping it up , just disassemble and clean up
but for now, im working on the o ring, and i need 2 bolts
nissan wont get them, someone at headquaters said whole caliper only
mitch33x
May 19, 2003 09:08 AM
Craig Mack
Aug 15, 2002 12:51 PM
breaux124
Aug 30, 2000 01:37 PM
