Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Question about rebuilding Z calipers:
Old Jan 6, 2007 | 11:18 PM
MaxBoost925's Avatar
Drug Money
Hey brake rebuild gurus,
I just replaced the rubber gaskets from the pistons in my '91 300zx 2+2 calipers today (30mm aluminum)
When I removed the original old gaskets, there was 1 metal circle clip and 1 rubber gasket in each piston.
Now in the rebuild kit i bought, it contained 4 pieces of rubber rings along with the replacement rubber gaskets...
My question is - were the rubber rings supposed to be used? Or did i just need to replace the gasket?
The kit was for 240z all the way to 300zx...
Thanks for the imput guys!
Old Jan 7, 2007 | 07:03 AM
irish44j's Avatar
retired moderator
are you talking about the seals that are down inside the cylinder? They have kind of a square profile...Once you pull the pistons completely out, you will see where they go.
Old Jan 7, 2007 | 09:27 AM
Drug Money
hmm, i didn't try that yet, i just replaced the outter seal.
the piston is a bish to pull out.
Old Jan 7, 2007 | 11:37 AM
irish44j's Avatar
retired moderator
two ways to do it:
1. but a wood block between them and use compressed air into the brake like opening to "blow" them out
2. I used a plumbers wrench and just twisted them back and forth while pulling out...was fairly easy. took about 5 minutes per piston.
Old Jan 7, 2007 | 02:01 PM
SurraTT's Avatar
HR Swap Pioneer
i just used a door panel remover tool they came out, fine once i got the fluid out
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Pied
Sep 26, 2015 03:29 PM
