Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
will 6th gen cal and ro fit under 18 x7 35mm offset?
Old Jan 28, 2007 | 01:46 PM
2k0to2k3's Avatar
i have a 5th gen 2k max and want to do the 6th gen brake upgrade, but not sure if they will fit under my 18 x 7 35mm offset wheels. does anyone know if they will? Or if not would the 300zx calipers fit? thanks really want to do this upgrade, ever since put the heavier, larger 18's on my braking has sig. suffered. then again i had the little 16 wheels. also will the stock 17"s fit on those brakes as well? thank you in advance to any that can help.
Old Jan 28, 2007 | 03:15 PM
irish44j's Avatar
retired moderator
The standard 6th gen setup will definitely fit (6th gen rotors/calipers). The z32 (300zx) calipers will be close and may or may not fit depending on the spoke style of the wheel. Might want to get in touch with jeff or matt blehm for the spoke clearance measurements if you're going to go that route.
Old Jan 28, 2007 | 07:15 PM
2k0to2k3's Avatar
thanks alot irish, greatly appreciated. I have lexus rx 330 wheels that are the 5 spoke. I had them machined to fit on our larger hub and i'm not sure if that would change the stock reading of 35mm offset or not. i guess i'll just try and see what happens.
on another note, i was going to just pm you directly, but figured since i've asked you 1000 questions before, i'd try the forum. lol but you answered anyway. thanks for all the past help and continued help.
i got to get some pics of my max up here since i've never seen another with my rims.Thanks again
Old Jan 28, 2007 | 07:52 PM
irish44j's Avatar
retired moderator
here's the diagram...
MAXSE5SPD
Sep 17, 2022 04:00 AM
I<3 A32's
Sep 10, 2015 11:07 AM
mclasser
Sep 6, 2015 09:05 AM
GregL65
Sep 5, 2015 09:37 PM
