Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
what nissan/ infiniti rotors will work on 30mm iron z3z
Old Jan 29, 2007 | 05:43 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
just as stated above
need to know what rotors will rork on 30mm iron z32 calipers that came from nissan/infiniti cars thanks
Old Jan 29, 2007 | 07:26 PM
irish44j's Avatar
retired moderator
well....the z32 calipers came on the......z32 (the early 1990s 300zx). Don't believe they came on any infinitis.....
For 4ht/5th gen Maxima applications, you basically have three choices:
1. shave stock rotors and fit z32 calipers on stock mounting holes
2. use 6th gen rotors + z32 calipers + Matt Blehm's brackets
3. use Cobra rotors + z32 calipers + Jeff's brackets
As to what will fit your Max, not really sure. Possibly would fit with standard z32 rotors (???)
Wait, am I reading your sig correctly that you have a z32 motor in your maxima? impressive.....
Old Feb 3, 2007 | 04:52 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
no its a z31 motor
as for rotors might go with 4th gen rotors
how much do i take off
Old Feb 5, 2007 | 09:38 AM
MaximaSE96's Avatar
Maxima Owner
y would use 4th gen rotors...one of the points of using the z32 calipers is to have thicker rotors.....3mm off the radius of 300zx tt rotors which IMO is still a waste......get matt or jeffs kit
Old Feb 5, 2007 | 10:41 AM
Matt93SE's Avatar
STFU n00b!
how big are your wheels, and how big of a rotor do you want to fit in there?
your best bet to fit under 16" wheels is to use the 30mm Z rotors and shave he 3mm off the outer edge. then it'll bolt up (assuming bolt patterns are the same. you might have to redrill to a 4 lug pattern).
If you want to go bigger, there's always my kit using the '04 maxima (Infiniti FX35) rotors and Z32 calipers..
Old Feb 5, 2007 | 05:56 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
i think that i will go with new cross drilled rotors
btw where would i get all the clips and pins for the calipers i lost some of them if someone knows where i can get them
i need the 4 long pins with the 2 clips
the 2 large caliper clips
and everything that im missing
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
RealityCheck
Aug 5, 2015 06:18 AM
