Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
spare tire clearance
Old Feb 19, 2007 | 06:04 PM
SurraTT's Avatar
HR Swap Pioneer
well, i have the z calipers and cobra rotors my spare will not fit front on rear, i dont like that, i would like it to atleast work in the rear
i was wondering if a spare tire front a 00+ max would work sence it should 17in wheel, and if it will fit in my spare tire place. anyone have experance with this???
Old Feb 19, 2007 | 07:04 PM
irish44j's Avatar
retired moderator
no, it will not. The issue isn't the 17" diameter, the issue is the offset. 00 wheels are a 42-45 offset and you need more like 30-35 offset to clear....the 00 wheels don't even come close to clearing the outside of the caliper....
EDIT: didn't realize you had the z32 setup on all four wheels....
best bet: another full-size with correct offset. Since I have 3 sets that clear my BBK, I just carry one of my track wheels (17x8, 35mm offset) as a full-size spare.
You can dig up a singe G35 coupe wheel (the 17x7.5/8) for probably $100 with a worn tire and just carry that....it will clear. Or just buy a cheap aftermarket wheel with a 30mm offset or so and throw a cheap/used tire on it as a spare...
Old Feb 22, 2007 | 06:16 PM
z32drifter's Avatar
Or you could use the "blow up" Z32 spare, if you can find one.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
JonBlz
Oct 5, 2015 06:02 PM
Garrettz459
Sep 28, 2015 02:50 PM
