Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
replacing suspension parts.
Old Mar 19, 2007 | 03:06 PM
MyownNismo's Avatar
Future Camaro SS owner
What parts would you replace when doing a strut replacement. I was thinking of replacing the strut bearings dustboots, spring isolaters.
Old Mar 21, 2007 | 07:31 PM
knapp9's Avatar
Bearing...a definite yes. The rubber spring insulator and rubber dust boot...probably yes because they can slowly wear out with use. Problem is you never really know if they need replacing until you take everything apart and look at them. Considering the overall cost & time to do the job, I'd go ahead and replace all the rubber parts so you have them on hand when you start the job and not have to make an extra trip with the car all torn up if you find you need them later on.
Old Mar 21, 2007 | 07:37 PM
MyownNismo's Avatar
yeah i got some info from the dealership on the parts I would need. Do the tokico Illuminas come with dustboots.
Old Mar 21, 2007 | 08:02 PM
knapp9's Avatar
Don't know, but seriously doubt it.
Old Mar 21, 2007 | 10:15 PM
MorpheusZero's Avatar
I'm replacing a crapton of parts next next weekend, got some konis, new springs, rsb, etc. I'm doing spring isolators/upper mounts, bearings and dust boots like you said. While you're down there you might as well replace your (quite possibly completely worn out) sway bar bushings with polyurethane ones, $12 for an endlink set and $12 for a frame set from the cattman group deal.
Matt93SE
May 24, 2019 02:58 PM
95Maxi
35
Sep 2, 2015 10:37 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
Team STILLEN
Aug 10, 2015 04:29 PM
