Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
BBK Install Help (measurements)
Old Mar 29, 2007 | 01:06 AM
th0ught's Avatar
I've got all the components in hand for the Cobra BBK setup, the only things I need are wheel spacers (running Murano wheels) and the hardware to mount the brackets. I've searched through as many of the old BBK threads as I could find, but couldn't find a clear answer. What are the measurements of the bolts needed to mount the brackets? Anything to point me in the right direction would be helpful, thanks guys.
Old Mar 29, 2007 | 08:05 PM
SNOMAX's Avatar
PM me for LCA's!
Well, the bolts are 12mm. As far as the length, I went to the hardware store and purchased bolts the same length as the stock hardware. You will also want to get washers, lock washers and a nylon locking nut. You can reuse the maxima hardware for the caliper itself. Hope that helps ya.
Old Apr 2, 2007 | 07:19 PM
th0ught's Avatar
^ Thanks man, I def. appreciate the help and I can finally get this BBK installed.
Old Apr 2, 2007 | 07:34 PM
Mxrider52's Avatar
I support for what?
Does anyone know the thickness of the relocation brackets used for the cobra setup?
AaronL
Nov 15, 2020 11:52 AM
BkGreen97
Apr 2, 2016 05:47 AM
Excalibur23
Oct 13, 2015 04:33 PM
blakkheartt12
Sep 17, 2015 08:11 AM
I<3 A32's
Sep 10, 2015 11:07 AM
