Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
ground control question???
Old May 3, 2007 | 07:37 AM
adriena's Avatar
i just got some ground controls and i'm messin around putting them on my car right now to see what the drop looks like. can these go with the stock shocks and struts??? i got the reaers on but cant figure out how to put them on the front. the sleeve wont fit over the strut. does anyone know how to put the ground control on the stock shock/struts in the front???
Old May 4, 2007 | 07:43 PM
Matt93SE's Avatar
STFU n00b!
1. no. stock struts aren't even stiff enough for stock springs. you'll look like a rathole civic with fleabay "coilovers" if you put them on the stock struts.
2. read the instructions that came with your kit. it shows you how and what to do to install them. IF you can't figure it out from that, then you don't need to be doing the install by yourself.
Old May 6, 2007 | 08:20 PM
MrDicks95SE's Avatar
Offset Is Everything.
modification of the strut is needed in order for the sleeve to fit. there should be instructions in the box.
and another thing, upgrade your stock struts. youll be so much happier with a working suspension rather than blown struts and a bouncy a$s ride.
Old May 7, 2007 | 05:03 PM
z32drifter's Avatar
The ground control kits are diff depending on the struts you are using. There is a kit that will fit the stock strut. Do you know what struts your kit is for???
Old Jun 7, 2007 | 10:08 AM
nismo_jt's Avatar
I too just recently bought some ground controls...the back i feel was properly installed..but the front...ever time i jack up the car..the cooils wud move around..any pictures of how it sopose to be installed?
Old Jun 7, 2007 | 11:30 AM
Matt93SE's Avatar
STFU n00b!
that's normal when you use a sleeve-over kit. the 8" long springs can't account for the 15ft long struts you guys have up front.
Old Jun 7, 2007 | 01:25 PM
RA030726's Avatar
I'm nutty for Nissans
go shortened konis or bust
Old Jun 7, 2007 | 02:01 PM
absoundlab
how good are the ground control coilovers?
Old Jun 7, 2007 | 02:04 PM
Matt93SE's Avatar
STFU n00b!
better than the fleabay sleeves, not as good as a real coilover.
Matt93SE
May 24, 2019 02:58 PM
Johnny9595
Sep 3, 2015 05:18 AM
95Maxi
35
Sep 2, 2015 10:37 AM
doobadoo
Aug 15, 2015 06:43 PM
