Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Brake Bias Question
Old Oct 24, 2007 | 09:47 AM
MAXimumHP's Avatar
Brake Bias Question
To keep this brief, I'm looking at brake options and have a question on figuring brake bias.
So the Maxima's proportioning valve has a split point pressure of 284psi, with a reducing ratio of .2
Does this mean that above 284psi the Rear pressure raises 20 percent less than the front? (or you could read that as 80 percent of the front pressure)
Or am I thinking backwards and the pressure only raises 20 percent of the front. That to me seems too small, but what do I know, I don't design these things. I guess it depends on how hard of braking 284psi is.
Can anyone verify exactly how this math works with certainty.
Also, as a long shot, can anyone quantify 284 psi? Is that like late braking, or standing on them before you hit the old lady in the Cadillac.
Old Oct 24, 2007 | 10:58 AM
Matt93SE's Avatar
STFU n00b!
at pedal pressures lower than 284psi, the pressure to front and rear brakes are equal.
above 284psi, as the pressure goes up 10psi in front, it only goes up 2psi in the rear.
this is to counteract the fact the car's weight is shifting to the front under hard braking, so the fronts need to do more work that harder you're on the brakes.
As for quantifying 284psi on brakes... that's a 'decent' stop. much harder and the car will begin to nosedive. full-on, almost-locking-the-brakes application is around 1000psi.
Old Oct 24, 2007 | 11:12 AM
MAXimumHP's Avatar
Awesome, Exactly what I wanted to know. Thanks Matt.
Old Oct 24, 2007 | 06:33 PM
MorpheusZero's Avatar
That's really cool--always wondered how the proportioning valve worked.
Funny, BMW had advertised this system (50/50 then like 70/30 under hard braking) as something unique to them a few years ago...
Old Oct 25, 2007 | 07:16 AM
MAXimumHP's Avatar
Some of the newer Nissans have the Electronic Brake Force Distribution system now, where I think each wheel is electronically controlled depending on several conditions. That's one of the reasons why when the Z and G came out they were kicking butt in braking distances. It's getting so much more sophisticated these days.
Old Oct 25, 2007 | 09:43 AM
soundmike's Avatar
Very sound, Mike
I've asked a similar question before and what i gathered from it is that EBD only affects brake balance between L and R, specifically the rears, not front and back.
At least that's how it supposedly is on 2002 Maxima's anyway.
Old Oct 25, 2007 | 12:57 PM
MAXimumHP's Avatar
Here's what I found on a Nissan website a while ago:
EBD - Electronic Brake Force Distribution
The advanced EBD system senses the load condition – of both passengers and luggage – to optimize rear brake force and control front and rear brake distribution for better braking effectiveness. It gives you the confidence of advanced braking control for safer, stress-free driving – whether you are on your own or carrying a full load of people and gear.
Old Oct 26, 2007 | 06:48 AM
Matt93SE's Avatar
STFU n00b!
Nissan's been doing it for decades... look at the rear subframe on 92-94 SE Maximas w/ abs (it was an option)... they have small bias adjusting valves attached to each side in the rear to account for body lean and cargo load in the trunk. the lower the car sits, the more rear brake it gets.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 16, 2015 07:20 PM
bbsitum
Sep 11, 2015 04:55 PM
