Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Will caliper innards rust if left in storage?
Old Jan 1, 2008 | 02:37 PM
n3985's Avatar
大陆弟弟
Bought a pair of rear calipers for use in the spring, so until then, can I just leave the calipers as is in the garage? Or will the lack of fluid start rusting on the inside?
Old Jan 1, 2008 | 05:44 PM
redls1's Avatar
MAXIN' ON
I would wrap in an old towel and lubricate with something. Maybe regular oil so it doesnt rust and then clean them when the time comes. Come to think about it I have my old rear calipers in the garage. Im not used to it getting cold. Gotta check on them.
Old Jan 1, 2008 | 05:46 PM
n3985's Avatar
大陆弟弟
Ya, they are wrapped in plastic in a box. Do you mean lube the inside? As in fill it with oil? Or even brake fluid?
Old Jan 1, 2008 | 06:24 PM
redls1's Avatar
MAXIN' ON
Not fill with oil. Just a light coating on the piston and area around.Yes lube the inside and around the lip.
Old Jan 1, 2008 | 06:32 PM
n3985's Avatar
大陆弟弟
OK, so no need to worry about the piston internals rusting? I mean w/o fluid it is exposed to oxygen....?
Old Jan 1, 2008 | 06:41 PM
redls1's Avatar
MAXIN' ON
To be honest I dont know. Was just trying to give a little input. I would think as you said the internals are open to oxygen and have a possibility of rust. Just worried of getting oil in there and then having a hard time getting it out. If you think you could do a little coating and be able to get it out of the inside. Might be good as well.
Old Jan 1, 2008 | 07:27 PM
!PrjctMax!'s Avatar
How about cutting the oxygen supply and blocking off the air by putting a little silicone paste on the openings of the valves?
Old Jan 1, 2008 | 09:52 PM
Matt93SE's Avatar
STFU n00b!
run some brake fluid through the caliper if it's completely dry.. close off bleeder screw and then cover the brake inlet with something- tape or whatever.
then spray the outside with a thin layer of metal protectant or grease on all of the external bare metal surfaces.
Old Jan 2, 2008 | 10:21 AM
n3985's Avatar
大陆弟弟
Thanks for the help Matt and redls1
But another question, if I am going to get the caliper powder coated, should I do it prior to a rebuild or after?
Old Jan 2, 2008 | 12:00 PM
!PrjctMax!'s Avatar
...^ wouldn't you want to do it AFTER so that it reduces the chances of knicking them during the rebuild...?
Old Jan 2, 2008 | 12:07 PM
n3985's Avatar
大陆弟弟
Ya that's what I thought too. But if baking to cure the powder, won't the caliper have to be bare i.e. no pistons or seals or boots?
Sorry for the n00bie questions.
Old Jan 2, 2008 | 12:09 PM
!PrjctMax!'s Avatar
on that one...I was just answering the questions that seemed more "logical" to me, and that one^^^ I'm not too sure about
Old Jan 2, 2008 | 12:16 PM
Matt93SE's Avatar
STFU n00b!
yes.
best way is to pull the pistons and all rubber seals and etc out of caliper before coating. insert a 10mm x 1.0mm bolt into both bleeder screw and brake line fitting to keep powder out of threads.
tape off inside of piston holes & etc to make sure no powder in there (generally let the coaters worry about taping it off.. they've done it before and know what to do).
when you get them back, buy a caliper rebuild kit and install new seals and such in it. lube the inside of the caliper with brake fluid, as per the directions. reassemble.
clean any brake fluid off powdercoating, and then coat bare metal piston surface with some grease to prevent rust (it really doesn't matter since nobody will see it, but if it makes you feel better then do it.)
that's about it.
Old Jan 2, 2008 | 12:20 PM
n3985's Avatar
大陆弟弟
Great, thanks for the info.
Now off to find someone locally to rebuild the calipers
Old Jan 2, 2008 | 09:41 PM
Matt93SE's Avatar
STFU n00b!
front calipers are easy. rear calipers aren't hard, but they're a pain.
Apr 16, 2020 05:15 AM
RealityCheck
Oct 2, 2015 06:34 PM
bigfrank
Oct 1, 2015 12:51 PM
uttadms31
Sep 30, 2015 05:24 AM
