Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
J30 BBK questions?
Old Feb 4, 2008 | 09:25 AM
BLACKonBLACK98's Avatar
Former Vendor
J30 BBK questions?
I had pretty much given up on upgrading my braking any further but I started reading about the J30 upgrade and it seemed like it was perfect for my application. I'm into deep wheels so the bbks i was looking into (z32 then willwood) kind of lost there appeal. I want to run a normal, or even super low, disk in the future so the J30 caught my attention when i heard they had stock clearance. I went ahead and ordered some reman. calipers, now on to the rotors/brackets. I know some have used milled oem rotors and some have used cobra rotors with Jeff's kit, but has anybody used them with Matt's brackets and 04 rotors? My understanding is that the J30/Q45 calipers have the same mounting dimensions as the Z32, and if they work with Jeff's they should work with Matt's too right? Am i missing anything here?
Old Feb 4, 2008 | 10:14 AM
Matt93SE's Avatar
STFU n00b!
I would think they should work if they work with the Cobra rotor kit and need the 3mm milling to fit the stock rotor with that caliper on the Max..
it sounds as if that's the case here, so I'd think they'll work.
Old Feb 4, 2008 | 10:28 AM
Former Vendor
whats the eta on your next run of brackets, or do you have any left? this might make a good (more) affordable addition to your brake lineup. j30/q45 calipers are pretty cheap and you don't need new lines.
ot: any update on your status for the meet?
Old Feb 4, 2008 | 04:31 PM
goon9's Avatar
I'm in for q45 brackets!!!
Old Feb 4, 2008 | 04:37 PM
Former Vendor
it wouldn't be a new product, just a new use of an existing one. what car is that in your sig?
Old Feb 4, 2008 | 07:43 PM
96blkonblkse's Avatar
The J30 caliper will bolt onto Jeff's bracket. They all used the same dimensions in respect to bolting onto the spindle. If you use the J30 torque member you will need J30 pads. Im sure you probably knew that but just in case. I had originally used the A32 torque member and J30 caliper but i wasnt happy with it, i wanted my 4 piston calipers lol.
I have Jeff's brackets sitting waiting to be installed, the corresponding holes lined up so i cant see why it wouldnt work. Jeff's require 13" Cobra rotors though.
Old Feb 4, 2008 | 08:06 PM
goon9's Avatar
...A maxima.
I want brackets to make the 13" rotors work, I suppose that means I'll need rings also. Are these out of production?
Old Feb 5, 2008 | 07:17 AM
Former Vendor
pm Jeff92se, he still makes the cobra kit afaik.
any full pics of that car? looks sick.
Old Feb 6, 2008 | 04:09 PM
goon9's Avatar
Looks like sin atm
There is afew in here
http://forums.maxima.org/showthread.php?t=551364
Old Feb 6, 2008 | 06:04 PM
SNOMAX's Avatar
PM me for LCA's!
You don't necessarily need rings if you get the holes redrilled on the rotors. There is a vendor who can sell them that way, if you haven't bought them yet.
I dont run the rings, but I have it redrilled.
Old Feb 7, 2008 | 09:46 AM
95maxrider's Avatar
Lightly modded
Did this eliminate the problem of the rotor 'unseating' itself when you take off a wheel?
Old Feb 7, 2008 | 10:05 AM
Jeff92se's Avatar
I'm needing a caw
For your information, I'm considering offering the brackets w/o the rings. My ring maker has backed out because they can't make them for the price they have before. If people are running these successfully w/o the rings (BUT USING THE REDRILLED COBRA ROTORS), then I'll just offer then this way. But I'd require the use of the redrilled rotors though.
Chime in.
Old Feb 7, 2008 | 11:04 AM
kzoosho's Avatar
Im in for brackets too. Seeing i need to upgrade the stoping since it goes better.
Old Feb 8, 2008 | 02:20 PM
Jeff92se's Avatar
I'm needing a caw
How's that been working out? Well I assume.
It's Automax in the Group deal forum that sells them this way. Recommened and will probably be a requirement to buy the Cobra rotors this way as I probably won't be offering the rings anymore
Old Feb 26, 2008 | 02:03 PM
Drivin Maxima's Avatar
Wait, I kinda got lost when reading the posts on the page........
So can I use J30 calipers and Bridges on my 98 SE as a direct bolt-on to my spindle?? Or do I need to get different mounting brackets??
And what rotors should I use????
Old Feb 26, 2008 | 02:08 PM
Jeff92se's Avatar
I'm needing a caw
J30 calipers + J30 rotors = need to shave 3mm off the radius. Then bolt on
J30 calipers + 13" Ford Cobra rotors = my brackets and need to purchase the rotors/pads/ss lines from Automax
Old Aug 26, 2008 | 11:02 PM
flatcat19's Avatar
Kinda noob-ish of me-Believe me. I have spent the last 3 hours searching...But will J30 calipers and rotors hit a 5th Gen? 2001. From all I've found-the only option 2000-01 has is BlehmCo's...I can't imagine that the spindle's would've changed enough that I have no options here. Thanx.
Old Aug 26, 2008 | 11:13 PM
flatcat19's Avatar
Old Aug 27, 2008 | 05:42 PM
As far as I remember, the 5th Gen front brakes are veeerrryy similar to the front 4th Gen brakes......if not the same.
I dont think youll have a problem....
PS I might be selling my J30 setup (check sig for details) with less than 6K on it pretty soon....
Old Apr 7, 2009 | 09:56 AM
2FrSh4U's Avatar
Hey, I've just bought a j30 BBK. It came with pretty much everything, the rotors, ss lines, brackets hardware, j30 calipers, pads, etc. However during shipment some of my packages got lost and ended up just receiving rotors =/. So can any one help me out on completing the BBK ? Anything up for sale that I'm in need of? Thnx
Old Apr 7, 2009 | 12:04 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
call the people that sold them to you and make them replace the lost stuff! don't just say "oh well it didnt' all come. too bad"... stand up for your right (to party)
Old Apr 8, 2009 | 07:57 PM
2FrSh4U's Avatar
Lol i wish it was like that. i bought it off a guy on the org and damn canada post screwed me =/ . i would of had definetly made them get me a new set if it were from a shop or suttn... know anyone that could help me out i would really like to get this daamn kit on lol.. worst case scenario anyone want j30 rotors ? lol
Old Apr 14, 2009 | 03:25 PM
Matt93SE's Avatar
STFU n00b!
ALWAYS insure your shipments.. doesn't matter where or who... reasons like this are why you do that.
Old May 11, 2009 | 08:36 AM
2FrSh4U's Avatar
IT was insured. got 250 backthats y im try findeiter a buyer or anter set of calipers
Old May 27, 2009 | 03:51 PM
Nealoc187's Avatar
SLOW
you can buy J30 calipers all day long at the junkyard for like $10 a piece...
anyways, to clarify something:
you do NOT need to do any milling of the rotor using J30 calipers with maxima torque members on a 3rd or 4th gen maxima. I've installed the combo on both. it's not a strictly bolt on affair though, there is grinding involved. search my posts or those of maxmaxima91 for more info, not gonna type it all out again right now.
Apr 16, 2020 05:15 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
