Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
what is in my rotor? (pic)
Old Feb 8, 2008 | 12:18 PM
chillin014's Avatar
Im going to take a picture of it right now.
I am replacing my brembo blanks with brembo slotted on the front and I noticed while looking at the profile of the rotor there is this metal wire going through about 3 or 4 of the cooling fins. is this some sort of weight for balancing? or should I remove it?
also ive got the rotors on correct right? this picture is of the passenger side of the car. outter part of the slot should be hitting the brake pad first right?
Old Feb 8, 2008 | 03:00 PM
MOHFpro90's Avatar
Looks like weight balancing to me. But I just got some powerslots in for a friends car and they dont have that.
They are on correct.
Old Feb 8, 2008 | 03:02 PM
chillin014's Avatar
thanks for the response. sucks i got some out of whack rotors i guess.
Old Feb 9, 2008 | 06:28 PM
Matt93SE's Avatar
STFU n00b!
that's pretty normal. they'll use that to balance the rotors instead of grinding metal off the other side to put it in balance.
personally I'd rather see it ground off on the other side instead of adding weight and something that might fall out later.
Old Feb 9, 2008 | 06:33 PM
chillin014's Avatar
thats what i was thinking....oh well...nothing i can do about it now. My brake pedal still feels frickin spongey. like the car just doesnt seem to ever BITE when I brake. I even embedded the pads...
Old Feb 9, 2008 | 08:34 PM
Matt93SE's Avatar
STFU n00b!
did you use 2 people to bleed the brakes?
what pads?
what fluid?
did you suck out all the old nasty fluid out of the reservoir before refilling with fresh fluid?
Old Feb 10, 2008 | 01:04 PM
chillin014's Avatar
what pads?
what fluid?
yeah 2 ppl. regular dot 3 fluid i forget the brand, one of the popular ones yellow bottle. no i didnt suck any old fluid out, i didnt want to create anymore air in there than there was before.
pads are metal master's.
Old Feb 10, 2008 | 01:59 PM
BLACKonBLACK98's Avatar
Former Vendor
i've been doing some research on brake fluid today and apparently old fluid is a cause of pedal sponginess. might want to flush it.
Old Feb 10, 2008 | 02:10 PM
chillin014's Avatar
damn. so are you going with that blue high performance stuff? or just fresh fluid
Old Feb 10, 2008 | 03:36 PM
Matt93SE's Avatar
STFU n00b!
pick up a bottle of valvoline synpower brake fluid from autozone. it's the best stuff you'll find for the price.
suck the old fluid out of the reservoir and pour fresh stuff in. then bleed one wheel at a time according to the FSM (or see stickies in 3/4/5/6 gen forums.). use 2 people. one to pump up the pedal about 3-4-5 times and hold it, then the second person to crack the bleeder screw open and let fluid drain out. when the pedal is on the floor, close the bleeder and have the guy ont he pedal pump up pressure again.
that's the best way to bleed these systems, regardless of what all the other forums and people tell you (and if anyone's bled more nissan brakes than me around here, I'd like to meet them. )
Old Feb 10, 2008 | 03:52 PM
chillin014's Avatar
thanks. yeah that sounds like how i was doing it. I do have one question though..when you open the valve the fluid squirts out right (i have a little clear hose on the end of the bleeder). So my question is, do you open it until the pressure stops pushing fluid out and then close the bleeder? Or do you open it and close it fairly quickly. Because I always felt like when i leave it open more than a few seconds the fluid is able to go backwards into the bleeder since the pressure is no longer there. you know what im sayin?
Old Feb 10, 2008 | 04:03 PM
Former Vendor
i'll let matt (or someone else) answer that since i don't know much about bleeding, but iirc you are supposed to close the bleeder screw once the brake pedal has bottomed out.
anybody got opinions on speed bleeders?
Old Feb 10, 2008 | 04:11 PM
Greeny's Avatar
¯\(°_o)/¯
Here's how me-n-my son bleed brake systems..
Son is the pedal pusher,I am the bleeder screw guy,(clear bleed hose into cup of fluid and wrench ready)
My son already knows the drill by heart now, but instruct your pedal guy to pump the brakes 2/3 times,then hold firmly on the pedal,when he signals ready, I open the bleeder, KEY PART HERE..Make sure your pedal helper is continuing to push the pedal until it hits the floor, then make sure he/she holds it there until you close the bleeder screw. Then repeat a few more times.
Communication between you and your helper is key if they haven't done this sort of thing before..
kzoosho's Avatar
Speed bleeders are fine . We use them at school all the time.
Old Feb 10, 2008 | 07:21 PM
Matt93SE's Avatar
STFU n00b!
I've used speed bleeders, but don't like them that well. with how picky nissans are about spongy pedals, I tend to recommend against them on nissans.
I even have a set on my 240 with the wilwood front/Z32 rear brake setup, and I do it just like they weren't there.
Old Feb 10, 2008 | 07:35 PM
!PrjctMax!'s Avatar
Alright, here's a question for ya...when does the bleeder screw guy close the valve? Do you let the fluid drain until it stops, or shut it before it stops? I would figure that when it stops, it would suck in more air, correct?
Old Feb 10, 2008 | 08:04 PM
Matt93SE's Avatar
STFU n00b!
when it stops. that's why you put a rubber hose on it.
Old Feb 10, 2008 | 08:21 PM
!PrjctMax!'s Avatar
So that's why when my dad and I bled my brakes for the first time they were spongy. No hose on it or anything, just a little bottle to have the fluid sip into.
What does the rubber hose do exactly? Prevent air from coming in?
Old Feb 10, 2008 | 10:16 PM
FishyMan's Avatar
I connect a hose to the bleeder and bleed. I can see the bubble in the air line tube. But after a few pumps of fresh fluid, the bubbles are gone, and the fluid changes from brownish to clear. hehe..
The LAST one, I do what was mentioned. PUMP HOLD and LOCK.
Old Feb 11, 2008 | 05:31 AM
Matt93SE's Avatar
STFU n00b!
Yup.
for the most part you're squeezing fluid out the house, but then the small air bubbles too.
but for the small volume that gets sucked back in before you close the bleeder, the hose prevents it from being air because its holding a decent amount of fluid right there at the bleeder.
Old Feb 11, 2008 | 06:09 AM
Greeny's Avatar
¯\(°_o)/¯
+1
I bought a speed bleeder some years back, didn't like the results at all, the pedal was still spongy. It's in the bottom of one of my tool boxes collecting dust..
Old Feb 11, 2008 | 11:06 AM
Matt93SE's Avatar
STFU n00b!
He's referring to the bleeder screw replacements that screw into the caliper.
Old Feb 11, 2008 | 11:13 AM
Greeny's Avatar
¯\(°_o)/¯
Nice animation..
I had another blond moment..
Old Feb 11, 2008 | 12:22 PM
Former Vendor
heh... geuss this thread was just a little late then. not only did i just buy a set of speed bleeders but i shelled out for the stainless version. oh well, won't be the first time i waisted some money. hopefully they'll work out for me though. i'm not as performance oriented as a lot of you guys.
Old Feb 11, 2008 | 12:35 PM
chillin014's Avatar
bling bling!!!
Old Feb 11, 2008 | 12:50 PM
Matt93SE's Avatar
STFU n00b!
You can at least say you have them and people will think you're cool.
Old Feb 11, 2008 | 01:57 PM
Former Vendor
they THINK i'm cool anyway. if they only knew...
Old Feb 11, 2008 | 05:10 PM
playboi21617's Avatar
looks like paper clips
Old Feb 11, 2008 | 05:17 PM
chillin014's Avatar
'preciate it.
Old Feb 11, 2008 | 06:53 PM
MOHFpro90's Avatar
Ok, so I am having the same issue, just bled mine with valvoline synpower stuff(big gold bottle), but still spongy. Let me get this straight, this is the order of things to do it in, correct?
Pump Brakes, loosen bleed screw, pump brakes once and hold down, tighten screw.
So you are not supposed to push and let go and push again if the screw is loose?
Old Feb 11, 2008 | 07:19 PM
Former Vendor
without being a brake bleeding pro and only having a general understanding of the way things work, if you release the brake pedal with the bleeder screw open you will be sucking whatever you just pumped out back in (assuming you have a hose/container connected).
Old Feb 11, 2008 | 07:51 PM
chillin014's Avatar
yeah dude....your doing it way wrong lolll. you dont let off the pedal with the bleeder open. try again. hold the pedal down while you are opening and closing the screw.
simple concept. sounds more complicated when written out.
Old Feb 12, 2008 | 06:00 AM
MOHFpro90's Avatar
Haha, well atleast I asked and got my answer. Time to bleed again.
Dont know if this matters or not, but when I did it this way, the fluid resvoir level went down.
Old Feb 12, 2008 | 06:55 AM
Former Vendor
refill.
Old Feb 12, 2008 | 06:56 AM
chillin014's Avatar
The fluid goes down in the resevoir because your pressing the pedal and pushing fluid out of the bleeder. So yeah you have to keep filling up the resevoir as the fluid goes down so you don't end up taking in more air and defeating the purpose.
Old Feb 12, 2008 | 09:05 AM
Matt93SE's Avatar
STFU n00b!
even doing it the wrong way, you'll still be pumping fluid out the other end. the issue is that youll be sucking in a small amount of air around the bleeder screw fitting and possibly the bubbles back in throught he hose when you let off the pedal and the bleeder is still open. all it takes is one or two itty bitty air bubbles to give you a spongy pedal.
BUT.. I've also noticed with some pads and fluid (usually valvoline doesn't do it tho..) that my pedal is always spongy right after bleeding, but firms up after 20-30 miles of driving. strange.. but it's always been find after I drove the car a while.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
Socalstillen
Sep 26, 2015 12:01 PM
