Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Brake pad options for q45 calipers?
Old Mar 13, 2008 | 04:49 AM
goon9's Avatar
Are there any Good brand of pads for these calipers? I can only find the regular generics. I was hoping to get hawk or ebc for them. Whoever is running them, what do you use?
I know greeny uses a maxima torque member to for maxima pads. The only problem is I think after using jeff's bracket it might push the caliper out too far? I donno...
Old Mar 13, 2008 | 04:58 AM
Greeny's Avatar
¯\(°_o)/¯
The main reason i ditched the Q torque member for the maxima t/m. No good quality pads available.(that i know of)
Old Mar 13, 2008 | 05:01 AM
Greeny's Avatar
¯\(°_o)/¯
I thought maxitech had hawk pads on his q45 retrofits? I never did touch base with him on that..
Old Mar 13, 2008 | 05:35 AM
Matt93SE's Avatar
STFU n00b!
There's a reason I designed my kit around a caliper off a sports car instead of a luxo-boat.
Old Mar 13, 2008 | 06:56 AM
Jeff92se's Avatar
I'm needing a caw
http://forums.maxima.org/showthread.php?t=351406
no problem
Old Mar 13, 2008 | 02:58 PM
goon9's Avatar
Oooh I see
*Hawk HPS Pads (HB415F.583 Will also fit 92-97 Infiniti J30 front calipers)
Old Mar 13, 2008 | 03:57 PM
maxitech's Avatar
Yes, I have Hawk pads and Brembo rotors made for the Q45 (same price as Maxima hardware). I bought from importrp (I think it was him). Q45 and J30 hardware should be interchangeable as far as I know...Just turn down the rotors 3-5mm and just make a slot in the shims. You should be able to tell where to cut when you test fit things. Search for a thread I did about it in May or June last year. Oh, and specify the Q45 parts as 92 or 93 for the model year.
Old Mar 13, 2008 | 06:05 PM
goon9's Avatar
Next question: On a 93, I don't see hawk part numbers, just run oem for the rear?
Also, if this a good price ? http://www.prostreetonline.com/pnsku/hb415f.583.asp
Old Mar 14, 2008 | 09:28 AM
maxitech's Avatar
Not sure about the rears...I still have drums FTL.
Post here, I'm sure importrp can tell you more about the rear pad availability than I can.
http://forums.maxima.org/showthread.php?t=316648
And that pad price seems fine. I paid $70 for mine.
Old Mar 17, 2008 | 04:25 PM
Iron Scimitar's Avatar
Tha Snatcher
I have those.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
