Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Excessive wear on inside
Old Aug 28, 2008 | 11:57 AM
ZIPPIN's Avatar
Mauja He Mauja
I have the 18" 350z wheels. Slight positive camber in the rear wheels. Today I noticed the insides of both rears are wearing excessively. Any ideas to fix that? Only the front is lowered with H&R. Rear suspension is stock.
Old Nov 17, 2008 | 07:11 AM
doublea's Avatar
It's kind of strange because with positive camber it's the outer that should wear faster !
I dont believe there is an adjustment for the pinch on the rear ( toe in toe out ) did your car has even been in a rear accident ?
Old Nov 17, 2008 | 10:19 AM
MrDicks95SE's Avatar
Offset Is Everything.
didnt we try to figure this one out already??
Old Nov 17, 2008 | 11:50 AM
MorpheusZero's Avatar
Sounds like your beam is bent.
Old Nov 17, 2008 | 03:29 PM
QNO_A32's Avatar
Old Nov 17, 2008 | 04:40 PM
Greeny's Avatar
¯\(°_o)/¯
if you haven't had the car aligned lately, do so.
Old Nov 17, 2008 | 08:37 PM
doublea's Avatar
Is this your car in the sig pics ?
I'd be concern as this tire is note made to go on that rim for obvious reason. lol
Old Nov 18, 2008 | 05:45 AM
Matt93SE's Avatar
STFU n00b!
1. If you have positive camber on the rear, something's broken. you car is set with -1* from the factory on a non-adjustable beam.
2. you probably need to lower the rear ride height. With as much drop as you put in the front, it tilts the rear suspension and causes weird alignment issues that weren't designed from the factory.
3. do you have an RSB?
4. when was the last time you rotated the tires? Checked inflation pressures? Are the tires matched?
5. When was the last time you had it on a 4 wheel alignment rack?
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
uttadms31
Sep 30, 2015 05:24 AM
