Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Q45 Brakes Squeaking
Old Sep 4, 2008 | 11:13 AM
maxitech's Avatar
For quite awhile I have had some squeaking coming from my front brakes. They don't do it at first when they are cold, just after they are warmed up with a few stops. I have the Q45 front setup. If I press on the brake pedal ever so slightly (not even enough to make the car slow at all) the squealing goes away. As soon as I release it comes back. It is VERY annoying driving in town. I pulled everything apart and regreased it with that clear brake lubricant in a tube, but it hasn't made a difference. Thoughts?
Old Sep 4, 2008 | 11:58 AM
MorpheusZero's Avatar
Sounds like you're on the wear indicators.
Old Sep 4, 2008 | 12:19 PM
95maxrider's Avatar
Lightly modded
Do you have Q45 rotors or Cobra? I have the Cobras, and even with Jeff's rings they aren't completely hubcentric. I have the same problem you have, and when I had my car on the dyno I noticed I could see the rotor spinning unevenly, so I'm thinking the noise could come from the rotor rubbing against the caliper since it's not completely hubcentric. I've had my setup for 2 years now with some auto-x, so maybe I should be checking my pads....hmm...
Old Sep 5, 2008 | 06:42 AM
maxitech's Avatar
It definitely isn't the wear indicators, the setup has only been on the car for a year or so. The pads are Hawk HPS and the rotors are Q45's made by Brembo.
Old Sep 5, 2008 | 10:02 AM
That's what I thought too... but I was wrong.
Symptoms point to wear indicators. Just take off your wheel and take a look.
Old Sep 5, 2008 | 01:56 PM
mowgli29's Avatar
Horizontally opposed.
yup, mine are the same way. stock brakes, but same symptoms. I checked out the pads and it's the wear indicators! I'm still waiting a while for pads though...
Old Sep 5, 2008 | 02:05 PM
Didn't you just rip the indicators off and keep going?
Old Sep 5, 2008 | 02:07 PM
mowgli29's Avatar
haha, not yet....but that is the plan!
Old Sep 5, 2008 | 02:17 PM
Norkoastal's Avatar
im looking into this mod for the I.. Is there a thread that covers all the parts needed to swap? Any installation tips now that you've both had some noise issues?
Thanks,
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
