Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
:D
Old Sep 20, 2008 | 09:09 PM
MorpheusZero's Avatar
:D
Even with the Konis at full firm this is underdamped.
But man oh man is it an improvement.
Old Sep 20, 2008 | 09:10 PM
Before:
After:
I got coilovers to raise my car up
Old Sep 20, 2008 | 09:20 PM
BLACKonBLACK98's Avatar
Former Vendor
so... uh... whats going on here? you got jsutters old a** frankenstein setup, still "underdampened", and no change in ride hieght? am i missing the point?
Old Sep 20, 2008 | 09:32 PM
Not really.
Old Sep 20, 2008 | 10:28 PM
G4nismo's Avatar
ehhhh
Old Sep 21, 2008 | 09:06 AM
Shove off
Huge improvement shortening the Konis and raising the spring rates... pillowball mounts are secks although I'm kind of iffy on the retaining nuts... I've checked em every time I went driving to make sure they haven't budged and so far, so good.
Old Sep 21, 2008 | 10:13 AM
Former Vendor
no slam no care.
Old Sep 21, 2008 | 10:16 AM
I am considering it just for ***** and giggles
But once I get an alignment I ain't touching it..
Old Sep 21, 2008 | 12:47 PM
Former Vendor
it would be awesome... but you already know that...
Old Sep 21, 2008 | 06:37 PM
http://forums.maxima.org/members-rid...ml#post6625363
Old Sep 21, 2008 | 09:37 PM
mowgli29's Avatar
Horizontally opposed.
Originally Posted by MorpheusZero
Shove off
I can shorten konis more than you (and still be able to use them).
you'd already know how if you'd freekin get on gmail
Old Sep 21, 2008 | 11:48 PM
IHAVEA2KMAXIMA's Avatar
Originally Posted by BLACKonBLACK98
Forgot Maxima-R
Old Sep 22, 2008 | 04:50 PM
Matt93SE's Avatar
STFU n00b!
Those Stillen or KTS camber plates? they look identical in color and design to the plates on my KTS coilovers for the 240.
Old Sep 22, 2008 | 05:04 PM
mowgli29's Avatar
and in fitment ?
is there just no hope for camber plates other than stillens? surely there's another car out there whose camber plates would fit an A32, no?
oh yeah, those are stillen plates.
Old Sep 22, 2008 | 09:33 PM
MrDicks95SE's Avatar
Offset Is Everything.
...this guy...
Old Sep 22, 2008 | 09:38 PM
OG stillen plates.
Originally Posted by Mr****s95SE
...this guy...
what!?
Old Sep 23, 2008 | 06:20 AM
Matt93SE's Avatar
STFU n00b!
Originally Posted by mowgli29
and in fitment ?
Dunno on fittment. the KTS for my 240 fit great and perform just as well. I do know for a fact the upper mounts are a slightly different bolt pattern on the 240. been there, done that, tried to stick a 240 mount on my Maxima. (and all 3-4-5 gens use the same bolt pattern and just about same track width... I run a 5 gen FSTB on my VE and it bolts right up.)
Then again, drilling a couple 3/8" holes in the fender well to mount a camber plate for a scooby, 240, bimmer, or whatever isn't hard. measure, mark, measure again, mark again, drill. I redrilled my strut towers on my car a couple times to allow for more camber and caster using the factory upper mount.
Old Sep 23, 2008 | 06:30 AM
mowgli29's Avatar
So theoretically, an A31 cefiro camber plate would work....do you think there's any reason the bolt pattern would be different than an A31 Max?
Old Sep 23, 2008 | 08:32 AM
Former Vendor
i'm not 100% on this, maybe matt or others will know, but i believe the a31 pattern is different (same as s or z chassis i believe, seems like i've seen some cross compatibility before). the a31 cefiro is not equivalent to the 3g maxima.
Old Sep 23, 2008 | 08:47 AM
mowgli29's Avatar
figures...isn't the a31 cefiro RWD? I guess that would explain it...
Old Sep 23, 2008 | 08:53 AM
A31 and S13 share front suspensions IIRC.
Old Sep 23, 2008 | 09:00 AM
mowgli29's Avatar
http://cgi.ebay.com/ebaymotors/_Car-...=p4506.c0.m245
that guy has them listed as 89-94 a31 cefiro AND maxima. either they both share the same bolt pattern, or this guy is smoking crack. But isn't this the guy that sells the jwt knockoff cams? I thought he was pretty reputable...
Old Sep 23, 2008 | 09:27 AM
paisamax's Avatar
what suspension setup is on the maxima se-r gtr?
Old Sep 23, 2008 | 09:33 AM
mowgli29's Avatar
koni sport struts with ground control coilovers and stillen camber plates.
Old Sep 23, 2008 | 09:35 AM
Former Vendor
my guess is he just assumed that since it was an a3* chassis there was a maxima equivalent. just a guess but i wouldn't spend $90 to find out he was wrong in this case (and i'm good for buying stuff that may work).
Old Sep 23, 2008 | 09:39 AM
mowgli29's Avatar
my thoughts exactly, but I may try and convince him to let me test it and see, at least at a discounted price. he could benefit from it because then he'd know wether or not he was falsly advertising!
I don't feel like putting forth the effort though because it'll most likely end up being a waste of time.
