Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
just bought z32 26mm calipers
Old Sep 29, 2008 | 07:33 PM
mastere954's Avatar
hello everyone, i recently purchased a set of rebuilt z32 aluminum 26mm calipers with pads, pins and z32 rotors. where is it exactly that i go from here?? i heard i caould use the rotors without milling them down but i also heard i had to mill them down. idk!! i dont need a relocation bracket right? also where can i find a brake line converter? since i am still using factory lines.. i realized that the calipers dont have the fitting for where the brake line connects. is that normal or is it something i need to get?
all help is appreciated and plz dont bust my chops cuz i did search, what i read just wasnt clear enough to me.
thanks again
Old Sep 29, 2008 | 07:45 PM
Fr33way™'s Avatar
Wild for Width
To answer one question out of that mess, if you just bolt the Z32s up without relocation brackets you will need to mill the diameter of the rotor and use conversion lines.
You should be able to find the conversion line for 240s...
Old Sep 29, 2008 | 07:48 PM
Fr33way™'s Avatar
Wild for Width
Originally Posted by Yahoo!
Z32/300zx Front Brake Conversion Lines for Nissan 240sx 89-98 S13/S14
Z32/300zx Front Brake Conversion Lines for Nissan 240sx 89-98 S13/S14 - These ... The brake line kits are made in the USA to meet strict D.O.T. certifications. ...
www.240sxmotoring.com/224z32brcoli.html - Cached
Site Map
... Line kit for Nissan 240sx 89-98 S13 S14 Z32/300zx Rear Brake Conversion Lines ... Lines Z32 Front/ 240sx Rear Combo kit for Nissan 240sx 89-98 Full Brake Line kit ...
www.240sxmotoring.com/ind.html - 146k - Cached
Z32 Brake Conversion Line: 89-98 240SX
Z32 Brake Conversion Line: 89-98 240SX - These brake lines are custom to fit the ... Brake Lines. Drivetrain . Clutches. Clutches. Short Shifter. LSD. Flywheel ...
www.optionimports.com/z32brcoli.html - Cached
Nissan
Brake Lines. Drivetrain . Clutches. Clutches. Short Shifter. LSD. Flywheel. Clutch Line ... HID Bulbs/ HID Conversion Kits. Side Markers / Corner Lights ...
www.optionimports.com/nissan15.html - Cached
Technical Articles: Q45 (1st Gen): Installing Z32 Brake Upgrade
Braided SS Z32 240 conversion lines OR You can use the factory lines*(SEE NOTE AT END) ... The hard line fittings are on tight so use an impacty wrench if you ...
www.nicoclub.com/articles.php?id=164382 - Cached
FRSport Z32 300ZX to S13 240SX Brake Lines
FRSport Brake Lines for Z32 300ZX brake calipers conversion on S13 240SX chassis. ... Well made, you can tell it is made in quality production assembly line ...
http://www.frsport.com/FRSport_Z32_3...es_p_7747.html - 87k - Cached
Circuit Sports Z32 Conversion Brake Lines - S13/S14
... steel braided brake lines for 89-98 Nissan 240SX with Z32 front brake conversion. Availability: Usually ships in 5-7 business days. MSRP price: $74.95Sale ...
phase2motorsports.stores.yahoo.net/cipz32cobrli.html - Cached
WTB: z32 ebrake assembly amd ss conversion lines: Nissan / Infiniti ...
Nissan Infiniti Forums for Maxima, 240sx, Sentra, Versa, Altima, Titan, 350Z, 300ZX, Skyline, Murano, Rogue, Xterra, G20, G35, I35, M35, M45, Q45, FX35, FX45, G37
forums.nicoclub.com/zerothread?id=349206&postid=3825987 - 86k - Cached
Heavy Throttle: Brake Line
View Cart | Checkout | Login | Search For Parts. Brake Line. Home - Policies - Staff - Contact Us. Copyright © 2007 Heavy Throttle | Website Designed by First ...
srownersclub.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=HT&... - Cached
Import Intelligence: Project S13C
Z32 Front calipers. Stainless steel conversion lines. Stainless steel rear lines ... Z32 Master Cylinder & booster. Interior: S14 Seats. S14 Seat Belt Conversion ...
www.importintelligence.com/reds13c.html - Cached
For example if you happened to use the web...
Old Sep 29, 2008 | 07:54 PM
Fr33way™'s Avatar
Wild for Width
As far as the relo, you don't NEED it for them to work. What it does is move the caliper further out on the rotor for more effective braking (imagine trying to stop a spinning bike wheel by using your two hands near the bearing versus grabbing the tire). People tend to take this route (brackets/cobra rotors) when they decide to go to the trouble of upgrading brakes.
Old Sep 29, 2008 | 08:43 PM
mastere954's Avatar
let say I go with a relocation bracket. Can I use the z32 rotors without having to mill them down??
Old Sep 30, 2008 | 06:41 AM
mtrai760's Avatar
'Trynna' is not a word
No. The relocation brackets are for the 13" cobra rotors only.
Old Sep 30, 2008 | 08:32 AM
mastere954's Avatar
gotcha. now how excatly does the whole brake line situation work??
Old Sep 30, 2008 | 08:46 AM
Jeff92se's Avatar
I'm needing a caw
Congrats but with the 26mm calipers, your only choice is to run the oem smallish Z32 rotors and mill them. If you want to run the 13" cobra rotors and my brackets, you need teh 30mm versions.
Old Sep 30, 2008 | 08:53 AM
mastere954's Avatar
ok so i guess i cant do the bigger rotors then. where do ppl take the rotors to get milled down ??
Old Sep 30, 2008 | 08:59 AM
MorpheusZero's Avatar
Any shop with a brake lathe should be able to do it.
Old Sep 30, 2008 | 09:13 AM
mastere954's Avatar
i work at a maroone dealership and i asked the techs and they tell me they've never heard of somebody shaving down the diameter of the rotor or how to do it..they have a brake lathe
Old Sep 30, 2008 | 05:39 PM
SmokinMax02's Avatar
Sounds like you jumped in with two feet first without knowing exactly what you have to do and why. Not too smart.
Do some REAL research and know what you're getting into before you throw down a bunch of money. If not, sell the parts and consider it a lesson learned the hard way.
Good luck!
Old Sep 30, 2008 | 06:03 PM
mastere954's Avatar
Good luck!
just a project my friend. my car isnt out of order. if i were depending on this for my car to be able to drive i would absolutely agree with you. plus i got the brakes for very cheap
Old Sep 30, 2008 | 06:38 PM
Matt93SE's Avatar
STFU n00b!
They're cheap because they're not much better than the stockers.
What year car?
the stock 2000-2001 rotors are larger diameter than the Z32 rotors and 26mm thick.
02-03 are an inch larger, but 24mm thick.
04-08 are 12.6" x 28mm.
the only good thing about the setup you have is the Z calipers, which have better selection of high performance brake pads.
As for milling the rotors down, anybody with a brake lathe can do it. they just have to take their time. I milled down a small stack of rotors last weekend using a standard Accu-Turn disc/drum brake lathe.
Old Sep 30, 2008 | 06:46 PM
mastere954's Avatar
I completely understand that. I know they arent alllllllll that. I just didnt want to spend the money on the 30 mm and all of the above for that setup. Guess I'm just really going for the look mostly. I love the look of these calipers. I would really like to keep the diameter if the z32 rotor cuz it is indeed larger than the stick 4th gen. Any thoughts on shaving the inside or the calipers a little instead??
Old Sep 30, 2008 | 06:50 PM
Matt93SE's Avatar
STFU n00b!
the stock 4th gen rotors are the same diameter as the Z32 rotors (11.02"), just thinner.
Don't even think about modifying the calipers. That's asking for catastrophic failure just when you need it most. just machine down the diameter of the rotors a small amount and call it a day.
Old Sep 30, 2008 | 06:54 PM
mastere954's Avatar
Ok. How much needs to be milled down??
Old Sep 30, 2008 | 07:03 PM
Matt93SE's Avatar
STFU n00b!
2-3mm, depending on what site you read.
Old Sep 30, 2008 | 07:27 PM
mastere954's Avatar
thanks for the help matt93se and everybody else. I really appreciate it
Old Oct 1, 2008 | 08:38 PM
z32drifter's Avatar
Depending on how soon your going to put the setup together I have a set of 26mm rotors already milled down. My car currently has the 26mm setup on it, but the calipers are junk. I'm going back stock until I decide what the next setup is going to be. The rotors are in good condition, if your intrested send me a PM.
BkGreen97
Apr 2, 2016 05:47 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
bbsitum
Sep 11, 2015 04:55 PM
Violator
Sep 9, 2015 10:14 AM
beerman1378
Sep 8, 2015 02:19 PM
