Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Disassembling K-Sports..have a few questions
Old Feb 20, 2009 | 05:39 PM
KrayolaSE-L's Avatar
Well, I just purchased some K-Sports and they are in need of replacement struts. My main question is, other that the difference in certain parts, are disassembling ksports similar to a regular spring/strut? I have searched the org, and put in plenty of time in on google and cant really find a definitive answer. And with that, are there other things that need/should be replaced or serviced with the replacement of the struts?
Also, upon inspection, it seems that one of the pillowball mounts has way more play that the other on the front strut. Could anything else be causing these, or do I need to just go ahead and order a replacement?
Old Feb 21, 2009 | 09:07 AM
Nobody has ever taken apart there K-Sport's themselves?
Old Feb 21, 2009 | 11:23 AM
BLACKonBLACK98's Avatar
Former Vendor
all coilovers are similar. the only wear items will be the dampers, bushings/pillowballs, and dust boots.
as far as disassembly, it's as straight forward as can be. remove the bolt that holds the tophat then the spring, bumpstop/dustboot, collars, and bottom bracket.
Old Feb 21, 2009 | 01:17 PM
That is what I have been told, I just wanted to make sure. Thanks.
Old Feb 22, 2009 | 06:55 AM
Snypa's Avatar
GL^^
Old Feb 22, 2009 | 07:35 AM
Originally Posted by Snypa
GL^^
With K-Sports that have about 35k on them I believe and covered in oil, I will definitely be needing it lol.
Old Feb 28, 2009 | 04:12 PM
yevrah4728's Avatar
and make sure u torque the nut for the pillow ball mount...or better yet use and airgun on it...
Old Mar 4, 2009 | 10:31 AM
Matt93SE's Avatar
STFU n00b!
That's why you don't buy Ksports..... 35k miles and they're done... throw 'em away and buy more.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
