Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
300zx Calipers
Old Mar 13, 2009 | 11:28 AM
2AZN2DMAX's Avatar
300zx Calipers
How much should I expect to pay for used 300z 26mm brake calipers?
thanks
Oliver
Old Mar 13, 2009 | 12:05 PM
Jeff92se's Avatar
I'm needing a caw
Why would you want them at all? They only use for them is if you want to go with the 26mm caliper and oem 300z rotor upgrade. Rotors are a pain to find for these 26mm units.
Do yourself a favor and just source the 30mm aluminum units. Or steel versions if you must.
Old Mar 13, 2009 | 12:42 PM
2AZN2DMAX's Avatar
I can get a set of aluminum ones for $80. Then all I would need is the brakeline and stock 300 rotors milled down 2-4 mm right?
Old Mar 13, 2009 | 12:47 PM
Jeff92se's Avatar
I'm needing a caw
You need to source the rotors specifically for the 26mm calipers but yes, that would do it. Along with the correct lines.
Old Mar 13, 2009 | 12:53 PM
2AZN2DMAX's Avatar
Wow. No brackets from you? LOL Direct bolt on then? Why is it hard to find the rotor for 26mm? What is the difference between the 26mm and 30mm caliper rotor? Thicker in width and diameter?
Old Mar 13, 2009 | 01:04 PM
Jeff92se's Avatar
I'm needing a caw
because the 26mm calipers are pretty rare. And since they are rare, I hear it's difficult to get the right rotor from the.
The diff inbetween the 26 and 30mm? About 4mm LOL. No dia differences.
I would recommend my parts but you are insistent on using the 26mm caliper. You're no good to me or to Matt. lol j/k.
You have one option with these calipers. 300zx rotor/caliper upgrade. That's it. Oh and 3-4 mm shave.
Old Mar 13, 2009 | 01:14 PM
2AZN2DMAX's Avatar
thanks for all of your help Jeff!!
Old Feb 1, 2010 | 05:29 PM
pat63's Avatar
hey thanks for all the info. i will forward this thread to my father. this would really a great help for him.
______________
==patrick65==
300zx parts
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
beerman1378
Sep 8, 2015 02:19 PM
