Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
When to replace Rear Rotors?
Old May 15, 2009 | 06:28 AM
ghostrider17's Avatar
I've eclipsed the 70k mile marker, and I'm on my THIRD set of Front Rotors& Pads, not counting ONE lathing on EACh of the first TWO sets!!
All the While, I STILL have the OEM Rear Rotors on the car. Although - I DID switch-out the pads to Hawk HPS around 30k miles.
I get ALOT of squealing from the rear shims, and occaisionally re-apply brake quiet material to quell the offending noises, but not often enuff.
Question is this: How do I tell when my REAR BRAKE rotors need to be replaced??
Pads still have life, but the rotors are starting to look a bit blue and discolored, although I can tell no difference in performance -- or have I just gotten complacent?!
Anyway -- just looking for a bit of advice.
I'm tempted to just throw-in a new set when time permits....but money's a bit tight these days.
input welcome!
gr
Old May 15, 2009 | 02:24 PM
MrDicks95SE's Avatar
Offset Is Everything.
take them to a shop and measure the thickness. thats the only effective way.
Old May 15, 2009 | 03:12 PM
MOHFpro90's Avatar
Couldnt you just use a caliper or micrometer to measure the thickness?
Old May 15, 2009 | 06:27 PM
BEJAY1's Avatar
Conecarver
Yep. FSM says 8-9mm thick min. Rears hardly get any wear compared to the fronts except when the caliper sticks.
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
RealityCheck
Aug 5, 2015 06:18 AM
