Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
4th Gen:Koni questions (adjustments, plastic rings)
Old Mar 11, 2010 | 01:57 AM
aic96max's Avatar
Ok, after searching i didnt find a difinitive answer
1.how do you adjust the rear strut as they dont have a dial know at the top like the fronts.
2. what are those plastic flat washers for?
3. are you able to adjust the rears when already installed?(they have an alan hole up top, but not sure if you have to comress while turning to adjust or whats the story. instructions suck.
Old Mar 12, 2010 | 12:03 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
http://www.koni-na.com/adjustment.cfm
Rear 4th gen Maxima Koni struts are the 8040 series. Since the rear alignment doesn't change you can remove the struts and put them back in with the need for a re-alignment.
However if you have the cash you can make them externally adjustable with rebound and compression but it will cost $200~$400 per strut.
Old Mar 12, 2010 | 02:24 PM
aic96max's Avatar
thanks for the link Joe. thats precisely what i needed.
Old Apr 2, 2010 | 12:45 AM
sergofast's Avatar
how do you make them externally adjustable? Would this really be necessary? if you adjust your shocks to the spring rates of whatever spring you are using why would you need to constantly play with the rebound adjustments?
Where do you have your rear konis set
MAXSE5SPD
Sep 17, 2022 04:00 AM
I<3 A32's
Sep 10, 2015 11:07 AM
mclasser
Sep 6, 2015 09:05 AM
Johnny9595
Sep 3, 2015 05:18 AM
Lowered_a33
Sep 1, 2015 07:49 PM
