Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
FAVOUR: Measurements for 4th Gen Stock Rear Mounts
Old Jan 20, 2011 | 01:55 PM
Bonka's Avatar
Schnell kaputt
I'm going to need to call in a favour here. I'm trying to get a member on another board to make some MEP style rear mounts for me and he needs to confirm the measurements of a pair of stock 4gen mounts that he has. I don't have any spares without disassembling the car so if anyone can spare a couple of minutes to measure up one that would be great.
As quoted:
..can you get me stud pattern diameter on those rear mounts so I can check against the oem uppers I have and confirm? Outside width minus the diameter of one stud, inside width plus one stud, measure with something as accurate as a dial caliper hopefully? Od on the mount itself, and stud diameter and center hole diameter too?
I know this is probably not the right section but I doubt I'd get any traction in the 4th gen section. Thanks guys appreciate it
Old Jan 21, 2011 | 07:09 AM
ajm8127's Avatar
The studs are 90mm on center. I'm in the process of fab-ing a rear brace and that's the diameter I used to place the holes for the studs. I measured it using the method described, with digital calipers; outside width of studs - 8mm, which is the diameter of one stud.
As for the center hole diameter, I am not certain. I do believe that the threaded part of the shock shaft is M8, and based on the pictures I've seen of the bushings, it looks like the lip that rides in the center hole in the mount extends 2mm on each side beyond the width of the hole for the shock stud. An educated guess is 12mm for the diameter of the center hole in the rear mount. Sorry for not being conclusive.
Huttig2009
Sep 25, 2015 03:31 PM
tcb_02_max
Sep 11, 2015 12:23 PM
homeyclaus
Sep 3, 2015 06:15 PM
Maxilano
Aug 31, 2015 07:33 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
