Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
stitch welding????
Old Jun 21, 2011 | 07:29 PM
bds1304's Avatar
stitch welding????
hey just wondering if anyone on the org, ever stitched weld all the seams to improve the structure of the uni body?
Old Jun 22, 2011 | 05:14 AM
ajm8127's Avatar
It's been talked about, but there is sealer in a lot of the joints so it would be a mess. Look into structural foam or SFCs if you want more rigidity. There is ample information to be searched for.
Old Jun 23, 2011 | 03:20 PM
bds1304's Avatar
ehh the seam sealer aint that big of a problems with the right tools.....but i have my car in my shop gettin stripped down and the front end fix so i gotta strip most of the sealer out anyway......figured that i might try it and see if it helps my massive wheel hop issue
Old Jun 27, 2011 | 11:14 AM
dsycks's Avatar
Sadly I doubt it would help your wheel hop. I am guessing you are getting this while drag racing or hard launches?
To fix that I would look at wheel/tire/suspension and a host of other issues prior to pondering seam welding which would add some structural rigidity without adding significant weight which is of value to road racers and the like.
Old Jun 27, 2011 | 06:31 PM
bds1304's Avatar
yeah im goin through and goin to put some new bc coils on it...and maybe some custom fender braces, and all new bushings,motor mounts and finish up my custom engine torque dampener
......yeah im goin to make a stupid kid move and throw all sorts of stupid money at this thing
Old Jun 28, 2011 | 03:49 AM
ElectricalBen's Avatar
I've been working on doing the front end, look at my build thread i have some pics
Old Jun 28, 2011 | 11:58 AM
Matt93SE's Avatar
STFU n00b!
stitch welding is a type of weld. seam welding is what you do to a car chassis to stiffen it up.
seam welding will increase the rigidity, but not in the amount you need to control wheel hop. fractional improvement when you need major stuff done. go read in the drag racing forum what people have done to solve wheel hop issues. the main things are better bushings in the suspension and subframe, as well as stiffer engine and tranny mounts.
Old Jun 28, 2011 | 02:53 PM
bds1304's Avatar
yep as stated above just some more stuff on the to do list
Old Jun 28, 2011 | 05:34 PM
ampire's Avatar
Subframe connectors and a cage would be more worthwhile.
Old Jun 28, 2011 | 08:26 PM
bds1304's Avatar
i like the idea of subframe connectors, just not the cage....its not that streetable
Old Jun 29, 2011 | 08:44 AM
Matt93SE's Avatar
STFU n00b!
Neither of them are going to solve your problem though. the problem is the loose front suspension and engine mounts. neither cage nor subframe connectors will go anywhere near there.
But yes, both will help stiffen the chassis and make the car handle and ride better.
Old Jul 1, 2011 | 03:47 AM
bds1304's Avatar
yet another thing on the to do list
Old Jul 23, 2011 | 07:12 AM
SM0KESH0W's Avatar
Probably urethane bushings and motor mounts would fix most of your issues...
Old Dec 13, 2011 | 07:02 PM
bigrak's Avatar
X2
Turbonut
46
Oct 21, 2015 08:28 PM
uttadms31
Sep 30, 2015 05:24 AM
lux97Max
Sep 28, 2015 11:18 PM
Hdnseek
Sep 9, 2015 05:55 AM
