Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
r33 calipers and cobra rotors?
Old Oct 10, 2011 | 03:21 PM
Brandon8965's Avatar
Has anyone ever used r33 calipers and cobra rotors on here.. i have searched extensively and noone seems to make the brackets to make this work.
I am thinking of making my own but if they exist then i'd rather take them from you.
Jeff's brackets put it far enough out for a 14in rotor but i already have the cobra rotor and don't feel like wasting my money.
the r33 caliper is made for a 296mm rotor and the z32 is 280mm.. so i need a bracket that is 8mm smaller but i has been a no go so far.
any help is greatly appreciated
Old Oct 10, 2011 | 06:00 PM
wirelessdude04's Avatar
Don't think anyone has done it. It's possiable someone on my350z did the GTR Brembo brakes on there Z and just had custom mounts made and the hub modified..
Found this as a reference
Old Oct 10, 2011 | 06:02 PM
Crusher103's Avatar
It will work, people have been doing it for a long time the same way they use Z32 calipers.
Old Oct 10, 2011 | 06:15 PM
They gotta be the R33 GTS- right?
Old Oct 10, 2011 | 06:26 PM
Crusher103's Avatar
yea no GTR. GTR brakes you have to use the Z33 rotor IIRC.
Old Oct 10, 2011 | 08:00 PM
thanks wireless.. i keep coming across that chart but thank you either away
yes they are the GTS-T calipers which per the chart use a rotor that is 18mm larger than the z32..
i guess i'm just asking has anyone ever even seen a bracket for a maxima or 240 for this type of setup?
Old Oct 11, 2011 | 02:20 AM
I'm sure for the 240 with how big that community is. Check zliva.net
Old Oct 11, 2011 | 07:32 PM
yea i sent a message to the one guy who i've seen that has recorded using r33 calipers and cobra rotors but of course that was back in 2006 so i'm not sure if he will respond but i'm still searching. :/
Old Oct 13, 2011 | 10:03 PM
Philli's Avatar
I've heard of a couple people using this company for brackets. They may have what you need or be able to make something up.
http://www.blehmco.com/brakes.htm
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 26, 2015 12:01 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
beerman1378
Sep 8, 2015 02:19 PM
