Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
300zx Relocation Brackets
Old Feb 28, 2013 | 05:47 AM
phatboislim's Avatar
anyone know what kind of metal/steel it's made from, the 'originals'?
brackets are on the right for reference
Old Mar 1, 2013 | 04:28 PM
ShocknAwe's Avatar
looks like it is cast to me. As for the type of steel, who knows?
Old Mar 4, 2013 | 12:17 PM
sprocketser's Avatar
These are casts .
Old Mar 5, 2013 | 05:37 AM
alright cool....anyone know of bolt info used to secure these and what not? is it a 3/8" dia bolt, correct? length?
Old Mar 5, 2013 | 06:38 AM
That I don t know , are these your Calipers & Brackets ! @ phatboyslim .
I would get in touch with either an Auto Parts or a Rebuilt Place & ask what they are , unless someone in the forum knows what it is .
Old Mar 5, 2013 | 07:29 AM
no a pic i found searching on teh forum trying to see if anyone by strike of luck had the caliper bracket material. i'm taking one bracket and making another set for another maxima owner. i no longer own a maxima
Old Mar 5, 2013 | 07:55 AM
ctsmith39's Avatar
I have the dog bone style and i would say it is around 1/2 inch steel as the suckers are heavy. Sadly that is the best that i can do.
Old Mar 5, 2013 | 08:38 AM
i have teh brackets in hand...i've kind of figured out all that..btw it's 3/8" thick...they are pretty hefty.
you dont remember the size of the bolts you used do you?
Old Mar 5, 2013 | 08:42 AM
Crusher103's Avatar
M12x1.25, about a 2 inch long bolt. Same size as the lug nut.
Old Mar 5, 2013 | 08:45 AM
ShocknAwe's Avatar
If you want to make another bracket hollar. I was going to have one made but never got around to it and this would be super easy for me . It would be nice to be able to use those spring retainer clips
Old Mar 5, 2013 | 09:56 AM
Thanx , can t read much the purple in sig , didn t noticed it before posting , sorry about that .
Old Mar 6, 2013 | 07:59 AM
thanks crusher..you dont know the diameter of it do you by chance?
i'm hopefully have the drawing down to have these made. i'm trying to have a test set made for someone right now and if these pan out i can work out getting a few sets made and just start selling them
that's cool dude, you're ok. preciate the help
Old Mar 6, 2013 | 09:09 AM
Crusher103's Avatar
Take any 17mm bolt off the car and thats the diameter you need. I think in your case with 5th gen uses 19mm bolts for the brake caliper so you might want to have the holes drilled out to that size.
Old Mar 6, 2013 | 09:23 AM
this isnt for mine, my max is gone... remember...i'm making these for someone else. hopefully The Law will answer up in his FS thread soon
Old Mar 9, 2013 | 05:18 AM
cjandura's Avatar
a366/1088 cold rolled steel its not cast! just order the thickness you need and then you have to order round stock i would stick with the same grade steel and just buy it to size calipers are your friend! you can also get stainless steel in 440 or 15-5 sheet and round eith one will do fine they all have a T strength above 95k psi.
the bolts are 12x1.25 i dont know the length
Old Mar 9, 2013 | 05:19 AM
cjandura's Avatar
These are casts .
the calipers are cast not the brackets
Old Mar 9, 2013 | 05:55 AM
Hey thanx buddy .
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Calabar
Oct 5, 2015 09:57 PM
-ReLLiK-
Sep 8, 2015 12:02 PM
