Post your all motor setup:
Got cams, pistons, rods, crank, etc etc......tell us what you got and where you got it from. I know of one company that makes 3.5l pistons, Im gona scan the ad tomorrow and post it.
My girls car has (motor, cams,exhaust, vq30det heads and flywheel are mine)
3.5 bottomend
JWT cams
3.0 VQ30DET heads
OBX headers
udp
MEVI
lightweight flywheel
3" exhaust with apexi black N1
centerforce disc with competition clutch PP
My car has a 3.0 boosted so wrong forum BUT I have 3.5 cp pistons
3.5 bottomend
JWT cams
3.0 VQ30DET heads
OBX headers
udp
MEVI
Wow! An all motor forum! My setup is:
WSP Cold Air Intake
WSP Ypipe
WSP Testpipe w/ electric cutout
ASP Under Drive Pulley
Maximum Tuning Valve Body Recalibration
Edge Racing 2500 stall torque converter www.edgeracingconverters.com
Ported throttle body and matched intake
Fully ported upper and lower intake manifold
Ignition timing advanced 5 degrees
Mazda Millenia wheels with 205/50R15 BFG G-Force Drag Radials
Weight reduction of 180lbs
And a bunch of stuff that didn't make me any faster in the 1/4 mile. I just listed the stuff that helped my track times noticably. Check out my website for a full mods list, pictures, and videos of my car.
WSP Cold Air Intake
WSP Ypipe
Ive got Intake, Greddy sp2 exhaust, Grounding kit, SWA UPD, waiting for cattman to release the 04 headers. Oh yeah im picking up a SAFCII local this week for 165 brand new. I dunno who im gonna get to wire this thing up, I know that no 04 maxima owners are using it but im sure it would wire up the same as an 02 altima or maxima. Glad to see we have an All motor forum!!
Intake, y-pipe back 2 1/2" Exedy Stage 1, Fidanza Fly, B&M
Soon - Front 95 manifold to rid of the front cat, extruded/honed intake manifold (if tilley didn't sell it yet) 95-96 ECU conversion, and maybe a tilley built engine down the road.....his girls car is just stupid fast for not being boosted
I have stillen high flow intake, with modded frankincar midpipe,Unorthodox crank pulley,cattman y-pipe ,cattman b-pipe,greddy muffler, 01 pathfinder TB,00 maxima VI 4750 rpm switch with TB port matched,00 max lower intake manifold with butterflys removed with holes welded and partly polished, and last JWT ECU 8000 RPM fuel cut
Fidanza/Exedy
WSP Y-Pipe
WSP Test Pipe
Greddy Catback
Jeffy/Shawn CAI
Port matched intake manifold
UDP (not installed yet)
sitting in a box:
10.5:1 CR Pistons
Will get to when I'm bored:
-Clean up headers
-Port TB
-Phenoic Manifold Spacers
theres probably crap I'm forgetting but who cares
WSP Y-Pipe
WSP Test Pipe
Greddy Catback
Jeffy/Shawn CAI
sitting in a box:
10.5:1 CR Pistons
-Clean up headers
-Port TB
Basics ( since i just started) WSP y-pipe
Ractive Performance Filter
Pr CAI
Next:
WSP B-pipe
??? Cat
??? Muffler
Don't think i want to mess with the UDP, Since i heard claims that it reduces your Elec output. And i'm not adapt enough to F*** with my cams and pistons and manifold yet. Thats where i sit back and learn from you guys
Pr CAI
Next:
WSP B-pipe
??? Cat
??? Muffler
I thought this section was for discussion of cars with more than basic boltons... not for everyone to post their I/Y/E setups?
Umm yea can someone delete my post, since now i know what all motor forum is or can a mod just move the entire thread to where it belongs or something?
Originally Posted by I30tMikeD
So what is the rule gonna be for "all motor" discussion....cams ok? stock 3.5 bottom end? or only internals?
just throwing my current setup out there...
VE30DE
rebuilt to stock specs with nissan bearings/rings
rebuilt VTC assemblies
Z32 NA pistons (10.5:1cr)
ported upper intake manifold
ported and matched throttle body/manifold inlet
throttle body and intake manifold spacers (1/4")
shaved stock flywheel
shaved ASP UDP (removed A/C rib)
hacked stock ypipe
2.5" ypipe back exhaust
stillen intake w/stock midpipe and bypassed resonator
exedy stageI clutch
TB coolant bypass
advanced timing
removed a/c system
walbro 255lph pump and 300zx fuel filter (if that makes any difference, i doubt it)
also have an SAFC thats not yet installed.
VE30DE
hacked stock ypipe
exedy stageI clutch
TB coolant bypass
advanced timing
removed a/c system
VE30DE
hacked stock ypipe
exedy stageI clutch
TB coolant bypass
advanced timing
removed a/c system
VE30DE
hacked stock ypipe
exedy stageI clutch
TB coolant bypass
advanced timing
removed a/c system
Really impressed with the work you have done.
there is currently more but its not power related
Question, you guys do these set up yourselves or you go to a machanic? Or you guys are mechanics?
.Allignment is the only thing I cant do, I can get close, but I still have a lifetime allignment to make sure things are perfect. Oh and Glass, I dont think I'll be attempting that anytime either.
I know Jeff and Pat are the same way
P.S. All-motor means more than bolt-ons people. My sig < all-motor...
Originally Posted by ny96max
Place Racing mid-pipe(chromed)
K&N cone filter
Hyper Ground Kit (4 and 8 guage wire)
RVM UDP
Greddy SP1 catback
Mobil 1 Synthetic Oil
Ant
K&N cone filter
RVM UDP
Greddy SP1 catback
Ant
I'm a little late but here it is.
Updated
Custom CAI
Full Race Exhaust 2.5"
Borla Pro Xs Muffler
NO CAT
WSPD YPIPE
SAFC II
A/F Guage
Oil Pres Guage
3.5 Bottom End
3.0 Heads
Secret Sauce ECU Upgrade
Ported Heads & IM
3.5 Cams
MEVI
High Performance Tranny Cooler
FSTB
Eibach Coilovers
Krome Racing Wheels
Khumo Ecsta 225 40 18"
and it's on on a Major DIET.
Updated
Custom CAI
NO CAT
WSPD YPIPE
SAFC II
A/F Guage
Oil Pres Guage
3.5 Bottom End
3.0 Heads
Ported Heads & IM
3.5 Cams
MEVI
FSTB
Eibach Coilovers
Krome Racing Wheels
3.5 Bottom End
3.0 Heads
3.5 Cams ***still pending***
MEVI
***DE-K VI under construction***
3.5 Bottom End
3.0 Heads
MEVI
Also are going to custom fit the 3.5 Cams?... or do they fit directly on?
Originally Posted by illmortal
So you're using a 3.5 motor with a 3.0 Head... or Mevi head?
yes 3.5bottom 3.0 heads on top, with MEVI.
the 3.5 cams I had to buy some spacers from JWT they fit just fine.
Actually I'm lookin to get this, even if I had to have some of it modified to work:
JWT ECU
JWT Cams (kit)
JWT Fuel Injectors
Headers
Y-Pipe
2" or 3" piping
Stock muffler or look alike (Borla/Magna Flow/Flow Master)
Looking for:
High compression Piston kit (Heads, rods, rings)
Higher stall rate Torque converter
Fuel Rail
Researching:
Will 3.5 Bottom End motor can fit onto VQ30DE Head
Fit 3.5 Bottom End with MEVI head (if this is possible I might just get the ECU with bigger fuel injectors and fuel rail and not the cams)
JWT ECU
JWT Cams (kit)
JWT Fuel Injectors
Headers
Y-Pipe
2" or 3" piping
Looking for:
Fuel Rail
Researching:
