Sponsored by:
Sponsored by: CARiD
Revving Higher??
Old Nov 5, 2004 | 07:45 AM
MaDMaX024's Avatar
Revving Higher??
Curious as to how high i can safely rev with my stock VE valve train..
Old Nov 5, 2004 | 11:04 AM
MaDMaX024's Avatar
Originally Posted by TopElement
Umm, you just rev higher. If you're not gonna change anything, what are you asking?
i was thinking 7200rpm would be nice...its about 700rpm more than stock.
as far as changing stuff, i have alot of mods and should be boosted by the end of may. as soon as the zemulator comes out for the VE ECU i'll be buying it, which allows me to set any rev limit, VTC crossover and since its for the actual VE ECU not the Z32, i should be able to set the VI crossover along with everything else the ECU controls (standalone on a stock ecu )
i'm asking how high i can safely rev without killing the motor. powerband will be determined on the dyno along with how exactly high i want to rev..i just want to know about what the absolute max is.
my motor is rebuilt to factory specs with less than 5000 miles on it (i also have 300zx 10.5:1 pistons)
Old Nov 5, 2004 | 07:07 PM
Aaron92SE's Avatar
NWP Engineering.com
The Zemulator software hasn't been programmed to support the VE VI yet. I'm sure it's possible. But until then, you will have to keep the stock VI release point unless you wire in an rpm switch.
But, as for the highest to rev in a VE... I don't think anybody has really tested the limits of the VE valvetrain. But, I'm sure if you just rev up to 7200 and shift, you should be fine. But if you revved 7200 in 3rd gear and held it for a while, that would probably float the valves. But I dont' ever plan to rev above 7200 ever with my stock valvetrain.
Have you ever taken your VE up to 7000 rpm? I have, it's a different motor. It's probably not making any significant power that high, but it sounds like a completely different motor above the stock 6650 rev limiter.
Old Nov 15, 2004 | 02:37 PM
3rdmaxse0's Avatar
I brong mine past 8 by accident long time ago (rookie mistake) shifted to 2nd from 3rd at redline aiming for 4th. scared me, idled for a sec sounded fine, rev alittle and back in gear to make up lost time.
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
uttadms31
Sep 30, 2015 05:24 AM
RWCreative
Sep 21, 2015 11:01 AM
