Sponsored by:
Sponsored by: CARiD
VE on our VQ?
Old Jan 23, 2005 | 06:50 PM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
VE on our VQ?
what is the Volumetric Efficiency on our VQ's?
Old Jan 23, 2005 | 07:13 PM
SR20DEN's Avatar
VQ Wizard
I know the VE on the 350Z is supposed to be 105%.
I do not know whet the others are. Supposedly less.
Old Jan 23, 2005 | 07:23 PM
pawnstar12's Avatar
damn, i guess im gonna go with the default 85%
Old Jan 24, 2005 | 05:58 AM
eng92's Avatar
VE is a strong function of RPM. Peak Torque occurs at peak VE.
Using MAF data and the calculated air density at the conditions I tested at, I came up with an approximate VE of .98 @4400rpm. VE was above 0.9 between 3200 and 5200.
This is for a VQ30DE. If you have VI or MEVI, the curves are significantly different. I can post the curves if you are interested.
Old Jan 24, 2005 | 03:08 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Based off these STOCK chasis dynos(withOUT drag):
VQ30 5th gen:
RPM--VE%
2500-78.86%
3000-84.61%
3500-88.02%
4000-86.26%
4500-85.44%
5000-81.33%
5500-78.42%
6000-75.58%
6500-69.2%
4th gen:
RPM--VE%
2500-77.88%
3000-75.58%
3500-81.68%
4000-80.10%
4500-79.96%
5000-78.86%
5500-71.69%
6000-59.97%
6500-47.77%
3rd gen:
RPM--VE%
2500-72.95%
3000-73.11%
3500-74.64%
4000-78.25%
4500-76.67%
5000-78.37%
5500-71.69%
6000-65.72%
6500-53.08%
Old Jan 24, 2005 | 03:19 PM
IceY2K1's Avatar
True...from 4000-6400rpm, the 350Z exceeds 100% VE, and at 5600rpm acheives 105%, thanks to CVTC, high angle intake ports, straightened intake system, and a focus on CAE modeling/airflow analysis of the intake plenum.
Pretty impressive for a street car to achieve >100% VE, since that's typically only seen on high RPM race engines.
Old Jan 25, 2005 | 11:52 PM
pawnstar12's Avatar
VQ30 5th gen:
RPM--VE%
2500-78.86%
3000-84.61%
3500-88.02%
4000-86.26%
4500-85.44%
5000-81.33%
5500-78.42%
6000-75.58%
6500-69.2%
4th gen:
RPM--VE%
2500-77.88%
3000-75.58%
3500-81.68%
4000-80.10%
4500-79.96%
5000-78.86%
5500-71.69%
6000-59.97%
6500-47.77%
since i will be using the vi from the dek, i should use the VE% from the 5th to caluculate the desired cfm for my new hp goal?
Old Jan 26, 2005 | 07:30 AM
IceY2K1's Avatar
I'd put it on and get a dyno with all your mods, then you can accurately calculate YOUR engines VE at varying RPM.
Old Jan 27, 2005 | 04:38 PM
Nealoc187's Avatar
SLOW
What is the calculation to determine VE?
Old Jan 27, 2005 | 11:19 PM
pawnstar12's Avatar
here is a link
http://www.installuniversity.com/ins...n_9.012000.htm
Old Jan 28, 2005 | 08:24 AM
IceY2K1's Avatar
That's a better way of calculating ACTUAL VE, since it takes into account air density, ie pressure/humidity/temperature.
What I posted it was approximations based off sea level and standard temp, since I was using SAE correced numbers, using the RayHall calculator: http://www.turbofast.com.au/freesoftware.html
Although, I'm not sure how RayHalls' calculator is 100% working, since it seems to assume a few things, I think, like Compression Ratio = 12:1.
Someone should use their OBD scanner and log a few WOT 3rd gear runs and dump them into Excel to get ACTUAL VE. Then it's just: VE=Actual/Theoretical * 100
Originally Posted by pawnstar12
Old Feb 2, 2005 | 10:52 PM
pawnstar12's Avatar
who has a obd scanner? i dont....can someone help us out?
Old Feb 7, 2005 | 11:12 AM
IceY2K1's Avatar
I tried this past Friday to get a scan of a 5th gen. while on the dyno, which would have been ideal for comparison, ie theoretical vs. actual with both on the dyno. However, my POS laptop battery was dead and my car DC/AC convertor blew and took out my fuses before I even left to the dyno shop, so no luck.
I have some stock and stock+POP OBD runs somewhere that I'll dig up and crunch in Excel.
Old Feb 7, 2005 | 10:26 PM
pawnstar12's Avatar
thanks man
Old Feb 7, 2005 | 11:45 PM
IceY2K1's Avatar
Still looking, all I found were second gear runs so far.
Old Feb 8, 2005 | 11:13 PM
pawnstar12's Avatar
cool...no rush. motor wont be in until july
