Sponsored by:
Sponsored by: CARiD
Whats the best NA IM design??
Old Jan 28, 2005 | 10:27 AM
  #41
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Or it's my polite way of saying your wrong.
Old Jan 28, 2005 | 10:32 AM
  #42
E55AMG2's Avatar
Wat
but hes not.....
Old Jan 28, 2005 | 10:50 AM
  #43
IceY2K1's Avatar
New 745i has VANOS, say again?
Old Jan 28, 2005 | 10:51 AM
  #44
E55AMG2's Avatar
Wat
Dual vanos
and I think you're a bit confused as to what vanos actually is.
Old Jan 28, 2005 | 10:52 AM
  #45
IceY2K1's Avatar
Still VANOS....
Old Jan 28, 2005 | 10:55 AM
  #46
E55AMG2's Avatar
Wat
so whats wrong then? he said they have the dual vanos AND the valvetronic.
Old Jan 28, 2005 | 10:57 AM
  #47
IceY2K1's Avatar
Pretty sure I'm not....
VANOS is variable cam timing
Valvetronic adds variable valve lift
Either or, you can't use their infinitely variable scroll type manifold design ideas, right?
Originally Posted by E55AMG2
Dual vanos
Old Jan 28, 2005 | 10:59 AM
  #48
IceY2K1's Avatar
"All current VANOS eqiuped BMW engines still have throttle bodies."
Current 745i has VANOS, yet doesn't have throttle bodies, since it uses valvetronic.
He corrected that.
Old Jan 28, 2005 | 11:00 AM
  #49
E55AMG2's Avatar
Wat
i guess i read it after he edited....
Old Jan 28, 2005 | 11:02 AM
  #50
IceY2K1's Avatar
It's still there, he just posted this to clarify to my implied answer:
Originally Posted by SR20DEN
The E65 745 does also have dual VANOS. So I should have said VANOS only BMWs still have throttle bodies. It is the valvetronic technology that negates the use of throttle bodies.
  #51
E55AMG2's Avatar
Wat
I dont think we could, being that we have no feedback loop to control it. Also, I dont think we have the space either.
Old Jan 28, 2005 | 11:04 AM
  #52
IceY2K1's Avatar
You 5.5gens with your CVTC could have something in common, but krismax and us VQ30s without that, wouldn't benefit probably.
Old Jan 28, 2005 | 11:05 AM
  #53
IceY2K1's Avatar
Actually, I think he was right in the first place, I forgot about this:
There is still a throttle plate, but it is only used as a failsafe or for certain diagnostic functions. Under normal operation, the throttle plate is held wide open, which means that there is no longer any vacuum in the intake manifold.
Old Jan 28, 2005 | 11:06 AM
  #54
E55AMG2's Avatar
Wat
I meant to say you guys...
Also, I dont think that our ECU has the capacity for more than two positions (on/off) for the manifold. So alot of the benefits of the scroll are lost.
  #55
E55AMG2's Avatar
Wat
Thats what had me so confused
Old Jan 28, 2005 | 11:09 AM
  #56
IceY2K1's Avatar
Man BMW are some sick puppies with what they come up with.
I talked with a BMW service techy A LONG TIME AGO when they first came out about the new 745i and he told me it still had a throttle plate, but wasn't used except as a backup. I just forgot.
BTW, I'd give my left nut for a 545i with that engine.
Old Jan 28, 2005 | 11:12 AM
  #57
E55AMG2's Avatar
Wat
Even the m3 has a throttle plate before the ind throttle bodies.
Old Jan 28, 2005 | 11:13 AM
  #58
IceY2K1's Avatar
I agree, however the CVTC can be controlled/modified to adjust the intake cam to whatever angle was optimal for the type of manifold, ie short or long or dynamic length, you fab'd. I think that's the bigger factor, but could be wrong.
Old Jan 28, 2005 | 11:14 AM
  #59
IceY2K1's Avatar
I don't care for that car, it's a toy, ie not practical for me, IMO.
Old Jan 28, 2005 | 12:02 PM
  #60
E55AMG2's Avatar
Wat
I was referring more specifically to the intake runner length. Like the BMWs is infinitely adjustable, whereas our ecu could only pick 2 spots.
Old Jan 28, 2005 | 12:15 PM
  #61
SR20DEN's Avatar
VQ Wizard
you get confused too easliy icey.....
No, I messed that one up.
Old Jan 28, 2005 | 12:17 PM
  #62
E55AMG2's Avatar
Wat
No worries, we figured it out.
Old Jan 28, 2005 | 12:20 PM
  #63
IceY2K1's Avatar
I'm not sure that's a problem. I mean if you can modify the VQ35 CVTC solenoid driver signal using a piggyback I've seen and a RPM switch or hell motorized servo controlled manifold that has 1, 2, 3 plenums, ie 1 long reach, 2 medium reach, and 3 short reach, you could vary the intake cam for each length.
Yes, that's not "infinitely variable", however with the VQ35s it wouldn't be that difficult assuming you could keep the ECU from throwing a VTC target angle code.
Old Jan 29, 2005 | 02:51 PM
  #64
DAREN's Avatar
Originally Posted by Jeff92se
i thought the the bmw m3 somehow had 6 individual throttle plates.
SR20DEN: thank for the verification
(i figure you can see my response here instead of a new post)
Old Jan 29, 2005 | 04:30 PM
  #65
SR20DEN's Avatar
VQ Wizard
The E46 M3 does (S54 engine).
That is a picture of a E30 M3 (S14 engine).
The E36 M3 (S50 engine) had only one throttle plate.
Old Jan 29, 2005 | 06:04 PM
  #66
spirilis's Avatar
Ford did 220hp in what? 1990? We had what? 160hp? But yeah, the only thing good on those SHOs was the engine.
A friend of mine used to drive a 1st gen SHO, he really liked it. Its engine went up and he hasn't bothered to get it fixed (yet he still has it --he drives a Saturn SL2 now) but he got to drive my 2K 5spd a few weeks ago and he really liked it; reminded him very much of the SHO, just more luxurious.
Old Jan 29, 2005 | 09:02 PM
  #67
SPiG's Avatar
SomePsychoGuy
Wow this thread is not or anything. Make your own BMW, SHO, etc. threads.
This thread is about a feasible IM design. Unfortunately it is a difficult thing to do with our hood lines, rear coil packs, and limited funds to produce something that would produce gains. Anything that you could make would be a trade off unless it was some kind of variable IM which I have never heard of an aftermarket VIM that worked.
One option would be the VQ30DET IM (I think tilley had it on his car) or some 350Z/G35 IM (either stock or some aftermarket) for their appropriate engines. Unfortunately those would require a new hood.
You could maybe modify one of our manifolds to make them better but I am not sure how that would work either. I can think of anything to make the -k signficantly better. The USIM could be extrude honed or something but not the best option. the MEVI could be EH possibly but even better if somehow it could be made to where there was no space between where the butterfly valves are when closed and where the runners should flow (like in the USIM). I am not familiar enough with the VQ35 manifold to say what could be improved upon it except maybe a EH.
Old Jan 29, 2005 | 09:48 PM
  #68
Broaner's Avatar
2060lbs and falling...
Has anyone ever attempted using the Swain flow coat? I think I may look into that next winter after I get mine EH'ed. Sport Compact Car used it on the IM and intake ports on their 300ZTT. http://www.sportcompactcarweb.com/pr...scc_proj300zx/
Old Jan 30, 2005 | 04:49 PM
  #69
goodhead's Avatar
http://e30m3performance.com/tech_art...sium/index.htm
Old Jan 31, 2005 | 09:00 AM
  #70
IceY2K1's Avatar
I disagree, the DEK/MEVI OEM manifold is designed for mostly low-mid range torque with its long runners and then uses a pseudo short runner design for the top-end by opening a secondary chamber.
We are looking at sacrificing low-mid range for top end without the use of complex individual throttle-bodies or variable length runners or any kind of valve timing.
Eliminating the long runners for a short runner design with proper intake runner length for desired peak RPM(rule of thumb is 90/(RPM/1000)???). So, if you wanted a 8000rpm peak, 90/8 or a 11.25" length from intake valve face to throttle plate. However, how you incorporate the plenum into this, I'm not sure.
Using velocity stacks/venturis would be nice, however creating the optimal suction port length is key.
Old Feb 1, 2005 | 08:52 PM
  #71
IceY2K1's Avatar
Something like this sheet metal short runner IM:
Old Feb 2, 2005 | 05:18 AM
  #72
stephenlc's Avatar
did you want to keep egr, and the pcv valve?
Old Feb 2, 2005 | 07:42 AM
  #73
krismax's Avatar
Father of the 00 VI
My egr is gone and pcv dont know yet.
Old Feb 2, 2005 | 08:11 AM
  #74
IceY2K1's Avatar
Any progress krismax or are you just going to toss a FWD VQ35 manifold on it?
Old Feb 2, 2005 | 09:18 AM
  #75
Broaner's Avatar
Why would you consider keeping the PCV? It just dirties it all up.
Old Feb 2, 2005 | 10:12 AM
  #76
Nismo3112's Avatar
Custom User Title
[QUOTE=IceY2K1]Something like this sheet metal short runner IM:
QUOTE]
I don't think that would be a good setup on our cars.. Our low end would suffer. For the Viper, it should be okay, a V10 should make some good tourque in the lower rpms.
Old Feb 2, 2005 | 11:05 AM
  #77
IceY2K1's Avatar
AGAIN, he doesn't care about low-end, he wants to make power upto 8000rpm, which requires short runners.
Old Feb 2, 2005 | 11:34 AM
  #78
E55AMG2's Avatar
Wat
how bout this...go get a flange machined to match the lower IM. Then, go get some short lengths of tubing welded to it and pop on one of those mesh screens on the tops of each. Then you have an old school short runner intake (reliability and keeping shiet out of the engine is another story though)
Old Feb 2, 2005 | 11:40 AM
  #79
Stephen Max's Avatar
Don't forget to convert to a MAP sensor based engine control system.
Old Feb 2, 2005 | 11:41 AM
  #80
E55AMG2's Avatar
Wat
Just put a resistor there to fool the ECU
