Sponsored by:
Sponsored by: CARiD
Need help with my 00VI!
Old Feb 23, 2005 | 03:14 PM
SDot82's Avatar
Exclamation Need help with my 00VI!
I just got my 00VI today and I saw that there were some pieces broken on the upper manifold the lower manifold,throttle body, and fuel rail and injectors are fine. For those that have done this do you think they could be fixed or should I send it back. Also could you help me with telling me where some of the hoses hook up at. Any help please, here are the pics of the manifold
Old Feb 23, 2005 | 05:10 PM
JamesNH's Avatar
that sucks. You get the im locally or off car-part? I saw an im for a fed i think in the mid west for 150$ on car-part if you return the one you have. I personally would return it and try to get a good quality one. You dont want the vibration of the engine slowly tearing apart any bonds you make with an adhesive if thats the route you where thinking.
Old Feb 23, 2005 | 06:44 PM
SDot82's Avatar
Damn I knew it, just my luck. So nobody thinks that something like J-B weld would keep it on there good enough? I will see what they say about the return.
Old Feb 23, 2005 | 07:15 PM
JamesNH's Avatar
Here you go http://www.kinggeorgeautoparts.com/ $150
http://www.dixonauto.com/ 200$
Old Feb 23, 2005 | 09:04 PM
Nismo3112's Avatar
Custom User Title
That broken piece is just a vacuum source. JB weld it up, and just Tee off another source. No big deal.
Old Feb 24, 2005 | 08:13 AM
jmeister's Avatar
Man that sucks...
check your email
Old Feb 24, 2005 | 09:23 AM
Stephen Max's Avatar
JB Weld works great on the 00vi. Something else I did to repair a broken off hose nipple is drill out the hole to a size just under the diameter of a brass hose nipple. Then heat up a brass male-male hose splice until it is hot enough to melt the plastic and press it into the drilled hole. The plastic will melt around the nipple and conform to its shape, and will grip it very solidly when it cools.
Old Feb 24, 2005 | 09:37 AM
SDot82's Avatar
Alright, thanks for the input it made my day a lot better I'm going to try them out wish me luck.
Old Feb 24, 2005 | 10:28 AM
One other thing, if you use JB Weld, or any other adhesive for that matter, surface prep is very important. Use acetone or rubbing alcohol to completely degrease the bond area before you apply the epoxy.
Old Feb 24, 2005 | 10:43 AM
SDot82's Avatar
Thanks again
Old Aug 26, 2005 | 07:12 PM
hdiggeddy's Avatar
JB weld for the 00vi
I have read something that said I need to put JB weld on my VI. I saw some guys Cardomain site but i cannot find the instructions anymore. Someone help me out. Thanks
Old Aug 29, 2005 | 05:38 PM
MaxGordon7's Avatar
Originally Posted by JamesNH
when looking up the IV, you need more then just one part or is there a speical name for the whole top of the engine?
t6378tp
Sep 29, 2018 04:27 PM
lrb6805
Sep 30, 2015 08:12 AM
Finkle
Sep 27, 2015 09:53 PM
Maximeltman
Aug 31, 2015 01:01 PM
skinnypimp
Aug 28, 2015 11:45 AM
