Sponsored by:
Sponsored by: CARiD
Help with instilling a 00VI
Old Mar 15, 2005 | 07:05 PM
SDot82's Avatar
Exclamation Help with instilling a 00VI
I need help from the people that did not use the egr, how did you close the pipe (block it off). And a question for those that used a 5th gen throttle body with the swap, how did you hook up the IVAC or IAVC ,its been a long night(did you use the 5th or what?).
Old Mar 15, 2005 | 09:00 PM
BSwithTF's Avatar
I made a triangle plate to cover the hole in the VI and got a plug to close the hole in the exhaust manifold.
I used the 5th gen IACV. All I did was swap the 5th gen IACV plug in place of the 4th gen one. The middle two wires match colors but the other 4 don't so I just hooked the others up accordingly. It has it's little quirks but it works good enough for me.
Old Mar 16, 2005 | 07:08 AM
SDot82's Avatar
okay I tried to get the pipe off the exhaust but there is too much stuff in the way so I can't get my wrench down there and move it. Could I block of the egr guide tube that goes into the manifold.
Old Mar 16, 2005 | 12:51 PM
BSwithTF's Avatar
That'd work if you could figure out a way to do it. Maybe cut the pipe, crimp the end, then put a little solder on it?
Old Mar 16, 2005 | 03:21 PM
SDot82's Avatar
That's my only option at this point unless I take out the entire egr system. One more question I dont have the 5th gen IACV plug so I'm rigging my 4th gen IACV plug to go into the 5th gen. I know that the 2 red wires stay in place but where do the other 4 go, if you could tell me what order they go in as if you were looking at the throttle body and the IACV was plugged in.
Old Mar 16, 2005 | 04:01 PM
SDot82's Avatar
bump........
Old Mar 18, 2005 | 08:33 AM
SDot82's Avatar
I was able to get the egr guide tube off and blocked it. Now I just have to put the upper manifold on and hook up the hose and figure out the IACV.
Old Mar 18, 2005 | 12:00 PM
jmeister's Avatar
Still wrestlin' w/ that thing?
I might head over that way on Sunday for the zclub auto-x. Wanna check out the hard work if you're around.
Old Mar 18, 2005 | 12:28 PM
SDot82's Avatar
I should be, I just keep running into things that slow me down alot. There is just one thing that is blocking me for getting the upper on it is a black plug it hits the bottom of the manifold . I think it is the PCV (correct me if I am wrong) does anybody have a way to fix thisand make it work?
Old Mar 18, 2005 | 01:01 PM
97GLE's Avatar
I think it needs either a right angle fitting put on it or you need one from a 5th gen (or remove it, don't know the pros/cons here).
Old Mar 18, 2005 | 02:49 PM
jmeister's Avatar
The right angle fitting is what I've heard too. But since you blocked off the EGR you should be able to plug up the PCV too???
Old Mar 20, 2005 | 07:01 AM
BSwithTF's Avatar
I finally got the wiring written down. Mine is set-up as follows:
1: yellow - yellow
2: red - red
3: purple/green - white/purple
4: gray/blue - gray/blue
5: red - red
6: yellow/black - gray/green
That's going from 4th gen wiring harness to 5th gen IACV plug. It looks like 4 of the wires matched colors instead of just 2 like I had originally posted.
Old Mar 20, 2005 | 07:45 AM
jmeister's Avatar
1: yellow - yellow
2: red - red
5: red - red
Thank you!
#6 is transposed I believe
Is this wiring setup w/ the correct idle or is it the random idle issue
Old Mar 20, 2005 | 10:44 AM
SDot82's Avatar
I didn't have the 5th gen IACV plug because my throttle body didn't come with one. So I just modified my 4th gen IACV plug as well as the IACV on the 5th gen throttle body and it plugged right up.
Old Mar 20, 2005 | 05:37 PM
BSwithTF's Avatar
Originally Posted by jmeister
Thank you!
It idles correctly (700-800) about 80% of the time. It dips to about 300 at stops sometimes but always jumps back up.
t6378tp
Sep 29, 2018 04:27 PM
lrb6805
Sep 30, 2015 08:12 AM
Finkle
Sep 27, 2015 09:53 PM
Maximeltman
Aug 31, 2015 01:01 PM
skinnypimp
Aug 28, 2015 11:45 AM
