Sponsored by:
Sponsored by: CARiD
00VI How To?
Old Apr 2, 2005 | 10:08 PM
  #41
MaxesRule's Avatar
Originally Posted by Stephen Max
I'm not sure anyone has converted the harness connectors and gotten it to work with the 5th gen IACV. Anyone know for sure?
Does anyone know the answer to this for sure? Also, can this be fixed by just using the 5th gen harness in the first place? I realize that on one end the harness connects to the iacv, but what does it connect to on the other side? A vacuum source like the upper im itself?
Old Apr 2, 2005 | 10:11 PM
  #42
MaxesRule's Avatar
Originally Posted by SDot82
The 5th gen throttle body comes with the iacv on it already, you need the 5th gen iacv plug to or did what I did and modify the 4th gen iacv plug to go into the 5th gen iacv since I did not have one.
Even though you modified the 4th gen iacv plug to fit the 5th gen iacv, you still have an erratic idle sometimes right? Again, would using the 5th gen iacv harness fix this?
Old Apr 2, 2005 | 10:15 PM
  #43
MaxesRule's Avatar
How does this swap affect the operation of the EGR system? Does the 4th gen system continue to work normally if unchanged during the install or must you retrofit the 5th gen equip onto the 4th gen or use all 5th gen pieces to make it work?
Old Apr 6, 2005 | 09:55 AM
  #44
MaxesRule's Avatar
ok?....where did everybody go? Was it something I said?
Old Apr 6, 2005 | 10:43 AM
  #45
Stephen Max's Avatar
If you install the 5th gen egr tube, then your egr will function.
Old Apr 6, 2005 | 10:55 AM
  #46
MaxesRule's Avatar
Thanks for the timely response krismax...but am I on my own for the other questions? I'd prolly get the requisite "Do a search newbie" if I post them again huh? Sorry if I'm asking questions to old answers, and feel free to ignore me in that case. Also, I'm not able to search on here.
t6378tp
Sep 29, 2018 04:27 PM
lrb6805
Sep 30, 2015 08:12 AM
Finkle
Sep 27, 2015 09:53 PM
Maximeltman
Aug 31, 2015 01:01 PM
skinnypimp
Aug 28, 2015 11:45 AM
