Timing Chain installed Correctly?
Before putting the engine back into the car, I need to know if I installed the timing chain correctly:
Left Sprocket, the right sprocket is identical, and matched w/ its mark.
Does this look right for ~TDC?
Thanks guys.
Thanks guys.
Originally Posted by nismology
That looks spot on. Are the marks on the secondary sprockets aligned with the marks on the secondary chains?
Yeah, the 2 yellow marks face each other, and when at TDC, the dowel pins face up? (10 and 2 oclock)
I check my 3.0 chain and sprockets today and it's EXACTLY like yours. Should be perfect that way.
Prepping the engine tomorrow (putting that sh*t back together, and fitting the 4th gen wiring harness and oil pan on). The car is still in the body shop so it won't be in the car till next week, but at least the motor/tranny will be ready...
^ Cool. The thing i'm most worried about this swap is getting everything put back together and have it NOT start, or have it not run right.... I would go nuts! Hopefully the timing chain is perfectly lined up
Don't worry the 3.0 ecu/wiring harness is not complicated. It's pretty straightforward. The 3.5 wiring and ECU, on the other hand, is a nightmare. I think I'm commiting brutal suicide if I ever have to deal with it again.
Originally Posted by vsamoylov
and your point is?
1. You had first-hand help from someone who had performed the swap already
2. Your car was down for a very very long time
3. You had to perform countless electrical customizations
So don't talk about it like it was a walk in the park.
It's your whole "ehhh...it's no big deal" attitude. You had to rip the dash apart for pete's sake. To me, that's a pretty big friggin' deal.
sorry to ***** this thread man.
Maybe, but at least you had a parts car. I scavenged parts left and right without knowing how they worked together. Comparing the 4th gen wiring harnesses to the 2k2, the 4th gen is much more straightforward.
There was 47 pounds of wiring alone just for the engine bay on the 2k2.
I agree.
Bump, any precautions I should take before starting this engine for the first time? I'm sure its been a while since this engine has ran. (BTW, startup won't be for a few more weeks, or until I get everything put back together, and all fluids topped off)
Dunno, but I bought the sealer/silicone (whatever you wantto call it) directly from the dealer, to seal the timing chain covers back together, and make sure it's the right one.
I have left:
-Install Flywheel/clutch
-Tranny
-Axles
-Water hardpiping
-Radiator
-Wires/Hoses
-IM/TB/intake
-Valve covers
-IACV valve
-Fill oil, coolant, tranny oil, ps fluid, brake fluid, and bleed brakes
The list seems to go on and on
How much more do you have left to do?
I have left:
-Tranny
-Axles
-Water hardpiping
-Radiator
-Wires/Hoses
-IM/TB/intake
-Valve covers
-IACV valve
I have left:
-Tranny
-Axles
-Water hardpiping
-Radiator
-Wires/Hoses
-IM/TB/intake
-Valve covers
-IACV valve
The flywheel was buffed a little (didn't need to be resurfaced), clutchnet 6-puck is in, transmission is bolted to the 3.5. Now I need to get off my lazy *** and install the cams/wiring harness and put that sh*t back together.
I do not need to buy anything, I have everything needed to complete the swap (including 3 brand new oxygen sensors). The car gets out of the body shop next monday (a week from now) and then I'll take an entire day off and try to get it running.
What I want to do is get the engine/tranny ready (right down to the wiring harness), so when the car arrives the only thing left will be to put it in the car, bolt everything up, plug, and pray to God I didn't f*ck anything up.
Hope it will be in and running in the same day. No more f*cking around, I can't drive the Tempo anymore. I'll go nuts. Bonkers. I can't stand getting smoked by 2.2 Cavaliers, stock Focus, Echos and Civics anymore. I just can't.
lol... Isn't the wiring harness still on the car though?
Have you figured out your fuel setup yet?
If vsamoylov is running fine w/ no fpr whatsoever and 3.5 injectors, We should be okay with an FPR and our injectors.
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
kirkhilles
Aug 8, 2015 10:53 AM
