Sponsored by:
Sponsored by: CARiD
high compression or low compression engine...
Old Apr 19, 2005 | 09:35 AM
ShRapNeR's Avatar
which one of these is our enginge... if any.. buddy told me to ask
high compression engine or low compression engine.
Old Apr 19, 2005 | 09:46 AM
2 Da Max's Avatar
its a high compression motor because it is not boosted from the factory.
Old Apr 19, 2005 | 09:48 AM
MDeezy's Avatar
I belive its 10.5:1 if I'm not mistaken.
Pretty high.
Old Apr 19, 2005 | 09:49 AM
Loe max's Avatar
IIRC our compression is 10.0:1 which is on the higher side.
Old Apr 19, 2005 | 09:53 AM
2 Da Max's Avatar
my boys LSVtec puts out 12.5 to 1, now thats high compressoin homie. then again max hp on that motor reaches @9k rpm so its pretty useless
Old Apr 19, 2005 | 09:56 AM
Bobo's Avatar
Yes it is 10.0 to one which is reasonably high. The muscle cars in the late 60s/early 70s were only about 10.25 or 10.5 to 1 on average.
Old Apr 19, 2005 | 10:08 AM
Jeff92se's Avatar
I'm needing a caw
You sure about that?
Jeff92se's Avatar
I'm needing a caw
You sure about that? I think only a select few muscle car engines could actually run that high of compression back then
Old Apr 19, 2005 | 10:11 AM
MDeezy's Avatar
(always good for a laugh)
Old Apr 19, 2005 | 10:59 AM
Chief Brody's Avatar
Mopar compression
Just whipped out my Cuda book (used to have one). 1970 Mopar 383 and 340 had 10.5 to 1, while the Hemi had 10.25 to 1. There were also 9 different engines available for the 1970 barracuda. Amazing stuff. So I don't think high compression was that rare back in the muscle car heyday.
Old Apr 19, 2005 | 11:01 AM
Jeff92se's Avatar
I'm needing a caw
I was guessing the hemi could run the high comp because of the head design. Could the others from the big 3 do that also? I think most makers had their select hp V8s that ran high compression. I just couldn't remember how common it was.
Old Apr 19, 2005 | 11:06 AM
I only know a bit about Mopars. They were still using leaded gas to help with resisting knock too. After 1971, forget it though, all makes got much tamer.
So yeah, the Maxima has 'spectable compression. It amazing me how well it holds up under boost considering this fact as well.
Old Apr 19, 2005 | 11:14 AM
20V6's Avatar
My commuter has a 23:1 ratio.... but that's an oilburner (diesel)
Old Apr 19, 2005 | 11:41 AM
JClaw's Avatar
VQ30DE=10.0:1
VQ35DE=10.3:1
And yeah, it is surprising how well the VQ handles boost/nitrous when well tuned. More than enough to make you wish it weren't unequal length axel FWD.
Old Apr 19, 2005 | 12:47 PM
NmexMAX's Avatar
dot dot dot ...
Jcalw^^ for the VQ CR's.
2 Da .. Just b/c it's not boosted from the factory doesnt mean it's high comp.
The CR for a '70 SS Chevelle was 10.5:1
Old Apr 19, 2005 | 02:44 PM
JClaw's Avatar
The CR on my dad's 1973 Trans Am is 13:1
Yeah muscle cars had high comp originally. Gas was way better back then. It was **** cheap, too.
Then we all know what happened. The mid 70's to late 80's mostly sucked for cars.
Old Apr 19, 2005 | 04:48 PM
stephenlc's Avatar
theres lots of hondas running 12:1 in Houston. They can run 10:1 on 87 so i guess its easier for them to run 12:1 on 93.
Old Apr 25, 2005 | 12:05 PM
Bobo's Avatar
My dad's 1967, 2-door Mustang sedan, came with a 390 cu. in. engine rated at 320 hp. Its compression ratio was at least 10.25 to 1. The highest gas mileage it ever got on the highway was about 13.5 miles to a US gallon and under 12 was routine. Mind you I used to drive it like I stole it.
Old Apr 25, 2005 | 12:56 PM
JClaw's Avatar
He drives it like it's rented
Old Apr 25, 2005 | 02:49 PM
japmaxSE's Avatar
Go Get a Life!
I think I have the highest comp right now 11.5:1
I can;t wait to feed it with super juice.
Old Apr 25, 2005 | 03:03 PM
NmexMAX's Avatar
dot dot dot ...
Gotta to jime for renting an 04+ and taking it to the track, and also, beating the bejessusz out of his LEASED 02 with N20.
Old Apr 26, 2005 | 06:43 AM
sonicrunch's Avatar
About the muscle car thing.....leaded gasoline had much higher knock resistance due to the lead. So it was easy to have higher compression with the better fuel.
Old Apr 26, 2005 | 08:07 AM
NmexMAX's Avatar
dot dot dot ...
Really ...
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
maxinout93
Oct 31, 2015 02:04 AM
