Sponsored by:
Sponsored by: CARiD
RPM Switch Reliability
Old Jun 18, 2005 | 03:21 AM
Curt's Avatar
Is there any concensus out there on whether the Harlan or the Summit RPM switch is any better than the other in terms of problems?
Let me know which you have and whether you like it or not. I'll keep a tally posted (below):
Brand/Like/Dislike
Harlan/1/1
Summit/2/0
Old Jun 18, 2005 | 07:14 AM
Stephen Max's Avatar
Brand/Like/Dislike
Harlan/1/0
Summit/0/0
Several people have had trouble with the Harlan switch, although I and a few others have had no problems whatsoever. I can't recall anybody having problems with the Summit switch (except for one person who didn't set the rpm properly). I have installed both in different people's cars and there is really no difference in difficulty of installation.
One possible advantage of the Summit switch is that it has a wire that provides a ground once the set rpm has been reached (which is what you would use to open a variable intake, for instance), and another wire that provides a ground up until the set rpm. The second wire may be useful in some applications. The Harlan switch only provides a ground after the set rpm has been reached.
Old Jun 19, 2005 | 08:32 AM
I30tMikeD's Avatar
Myself, like many others, had problems with the harlan. It worked fine for a while then radomly flaked out. The bad thing about it is that when it flakes out and does not activate the solenoid it won't work again till the car is shut off and restarted. So you would be driving and it would be working fine, then all of the sudden it would stop working and you would have to pull over and turn the car off.
Eventually the harlan switch hardly ever worked. I trouble shooted for a long time with this problem. Re wired everything, changed vacuum canisters, etc....finally just got the summit switch and had no problems since.
Old Jun 19, 2005 | 11:57 AM
Nealoc187's Avatar
SLOW
In my mind there is absolutely no comparison between the two. Summit is the far superior switch. I had nothing but problems with the Harlan. Total waste of money.
Old Jun 19, 2005 | 11:33 PM
NmexMAX's Avatar
dot dot dot ...
I went throught 2 Harlans before I wised up and got a Summit, been in there for about 2 years, and no problems yet ...
Old Jun 20, 2005 | 06:18 AM
SDot82's Avatar
That was me, I didn't realize it was made for a V8 but once someone told me what I should set it on I had no problems.
Old Jun 20, 2005 | 07:21 AM
SPiG's Avatar
SomePsychoGuy
That is the only disadvantage of the Summit switch. It is set up for a V8 so the RPM increments are not correct. I know the MSD has a correction for it. Besides that it is a good switch from what I hear.
Old Jun 20, 2005 | 09:18 AM
96sleeper's Avatar
Harlan was a POS and messed up alot, got a summit and not one problem yet in 2+ years.
Old Jun 20, 2005 | 09:20 AM
DandyMax's Avatar
3.5 in the works
+1 for the Summit. It's nice having the extra output type too.. (normally open vs normally grounded).
Old Jun 20, 2005 | 09:26 AM
JeffesonM's Avatar
living out of a maxima...
I've had no problems with my Harlan, but I seem to be in the minority.
Old Jun 20, 2005 | 10:39 AM
Maybe not. People that have had problems are the most likely to give an opinion. But I have two of them with no problems, and I know of another person who had four of them operating different devices with no problems. It's probably an installation issue.
gavin68
Sep 18, 2021 12:36 PM
mkaresh
Mar 12, 2018 06:48 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
